View Full Version : How to mount a vacuum cleaner nozzle?
Boucher
12-22-2009, 11:06 AM
I have been mulling this question over in my mind. Thinking about trying to catch the chips on both the lathe and the mill. Has anyone done this? The mill seems a little more straight forward as the cutter is fixed and the material moves. Some time back there was a reference to a cheaper Noga type camera mount. I have not been able to find that reference. That would appear to be one way to readily position the holder for the mill.
A rear mount tool post attachment for the lathe seems to have some merit.
Has anyone done anything like this?
Frank Ford
12-22-2009, 11:16 AM
That was probably me. I have three of those Bogen (Manfrotto) Magic Arms, and I use them all over the shop now.
Here's one holding my "sky cam" over the lathe:
http://www.frets.com/HomeShopTech/Shop/SkyCam/skycam02.jpg
I have it mounted on the wall with a jointed extension arm so it can reach anywhere over the lathe.
Here's another holding the vac attachment at the mill:
http://www.frets.com/HomeShopTech/Tooling/MillLightBar/milllightbar03.jpg
I just made up a bunch of aluminum dovetail plates to fit the quick release holder so I can handle a variety of different things from air blow nozzles to propane torches. The Magic Arm makes a great third hand at the bench.
Black_Moons
12-22-2009, 11:19 AM
Hmm, Iv made a similar but larger scale arm outta bits of tubing and square channel, long before I got my mill for holding peices in precise arbitary positions for welding... i'll take some pics if anyone is intrested
BWS
12-22-2009, 02:27 PM
coat hanger.....stainless tig rod if trying to impress.BW
ehughes
12-24-2009, 12:12 PM
For what its worth here is what I did using 1" PVC pipe and 3/4" Loc-line. I think Frank's setup is better, though. Magic arms definitely going on the want list. Thank you Frank. Regards, Earl
http://i151.photobucket.com/albums/s144/ruralearl/12-24-09003.jpg http://i151.photobucket.com/albums/s144/ruralearl/12-24-09002-1.jpg http://i151.photobucket.com/albums/s144/ruralearl/12-24-09004.jpg
If I did the photos right, that is.
Davidhcnc
12-24-2009, 02:15 PM
Would there be any problems with static discharges when sucking up chips?
I am thinking of machining plastic on a cnc mill.
RKW
12-24-2009, 02:38 PM
Probably with just about anything dry. I have been shocked many times over the years from static from my shop vac and can always see dust on the outside of the hose standing up as a result of the charge. Possibly adding a ground strap with a current limiting resistor or a static drag chain on the underside might help cut down on static buildup.
