View Full Version : Tubalcain's Lever Operated Dril Drift
kcleere
12-25-2009, 01:08 PM
I was watching this gents video on morse tapers and he was using a lever operated drill drift that I thought was cool because it covered many tapers...
Anyone know where one of those can be had?
shadoof
12-25-2009, 02:16 PM
Do you have a link to the video or is it a dvd you're watching?
Lee
kcleere
12-25-2009, 03:13 PM
Lee
If you watch this through you'll see him with two different kinds near the end.
http://www.youtube.com/watch?v=JHNdrl7KKNc
dp
12-25-2009, 03:33 PM
http://cgi.ebay.com.au/SEMI-AUTOMATIC-MORSE-TAPER-SHANK-DRIFT-FIT-MT4,-5,-6_W0QQitemZ380182854807QQcmdZViewItemQQimsxZ200912 01?IMSfp=TL0912010010001r8195
http://grizzly.com/products/Semi-auto-Morse-Taper-Key-1-3/H7959
dockrat
12-25-2009, 03:53 PM
for those tapers that don't have a tang...use a plastic fallers wedge with a slot milled in it and give it a tap with your hammer.
http://i253.photobucket.com/albums/hh67/Dockrat1/IMGP1265Medium.jpg
John Stevenson
12-25-2009, 06:55 PM
I have one based on a brass slide hammer, they used to be vary popular here but I have done a search and can't find one to link to.
Mine came from a works clearout with some of the lever ones but all the lever ones were broken so never had the chance to try one.
This slide hammer one is very old and battered but works everytime, simple one handed operation even on very stuck tapers.
I'll get a picture tomorrow and post it, they would be very easy to replicate, far easier than the lever type.
John Stevenson
12-26-2009, 10:11 AM
OK pretty pictures.
http://www.stevenson-engineers.co.uk/files/slidedrift1.jpg
Sorry I didn't file all the marks off and polish it but it's been in use too long, clearly marked Bargon hammer drift but Google doesn't pick that up.
Second pic to show the insides.
http://www.stevenson-engineers.co.uk/files/slidedrift2.jpg
And last pic to show the spring arrangement better.
http://www.stevenson-engineers.co.uk/files/slidedrift3.jpg
In use you push down on the hammer handle and the spring extends until the top of the drift hits the top of the hammer head, typical slide hammer action.
Crap video here of it removing a MT2 drill from a MT4 sleeve, doesn't show a lot as it's so quick and normally one handed if it's in a quill or tailstock. Done it a couple of times to show, sorry for the quality.
http://www.youtube.com/watch?v=2qunwxRttzE (http://www.stevenson-engineers.co.uk/files/P1000923.MOV)
Forrest Addy
12-26-2009, 10:56 AM
Here' the exact thing:
http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=17737025&PMT4NO=76771887
Pretty spendy but the import ones like I have are about $45.
John Stevenson
12-26-2009, 11:01 AM
Yes that's the lever one, anyone seen the slide hammer type I posted ?
I had about 3 or 4 lever type but all had missing teeth off the rack so I never had a chance to try them, had two of these slide hammer types but one has gone walk about.
JCHannum
12-26-2009, 11:14 AM
The slide hammer is something I haven't seen on this side of the Atlantic, it is interesting.
As to the lever type, they turn up here and there but a well stuck MT will still require agressive use of an engineer's hammer to remove and even that will fail at times. That might account for the stripped teeth.
Black_Moons
12-26-2009, 11:38 AM
Mmm, those lever types look like they could do with replacing the rack with a thread, and replaceing the lever with a nut, and like a giant wingnut (tabs welded onto a large nut works wonders, and can still let a wrench onto the nut for high torque) or tommy bar.
dp
12-26-2009, 12:58 PM
Here's a modern slide hammer version. http://www.drillspot.com/products/503633/dayton_55100_morse_taper_drift_tool
I think I'd prefer not to knock on my machines too hard. I may discover inclusions and weaknesses I'd rather not know about :) Then again, none of my tapers are slotted or tanged - all use drawbolts. Banging on them is doing enough damage. http://metalworkingathome.com/?p=42
