View Full Version : 4 axis CNC work
sdeering
12-27-2009, 11:51 AM
Some barrel fluting.
Enjoy
Stephen
http://img.photobucket.com/albums/v510/sdeering/DSC00499.jpg
http://img.photobucket.com/albums/v510/sdeering/DSC00501.jpg
BobWarfield
01-04-2010, 09:33 PM
Sporty!
BW
Ken_Shea
01-04-2010, 09:51 PM
Really like the look Stephen, curious, did that fluting have any effect on the shot group size or pattern?
sdeering
01-05-2010, 08:32 AM
I’m not sure yet. Haven’t shot it. The barrel is kind of a ginny pig of sorts. I bought it to practice chambering on and have shot it quite a bit. I think it had 2500 rounds through it when I got it. Probly. 500 more. I had to recrown it after the fluting because the tailstock I was using deformed the the crown, not much but crowns need to be perfect. I is possible that the barrel could have warped from the work. I think it was button rifled.
The flutes are .05 deep done in one pass with a 1/2 carbide ball nose end mill.
I will get back what I test it out.
Thanks for the interest.
Stephen
madman
01-07-2010, 09:53 AM
I tried Many years ago to do some straight fluting on a Barrel. Had lots of trouble with the finish (I used a end mill tilted at a bit of a angle and a homemeade wooden tailstock block clamped tightly onto the barrel end. I had the gunsmith tell me the Barrel was Junk and warped? Whatever, I didnt take much material out. I should of uses a slotting cutter? Anyways yours looks awesome Good Work.
SMITHelectrics
01-07-2010, 11:28 AM
Mr. Deering;
I see from your description that you are using a series 1 BPT mill that you have upgraded. I need a saturable reactor which was used in the origonal drivers on this machine. Would you by chance still have some of theese older drive parts? thanks smithelectrics@twcny.rr.com
