View Full Version : gizmo-almost done... pics.
wagnerite
01-09-2010, 09:56 PM
oh my, i hope i dont get into trouble for this.
5/8" SS bar, bent on a JD2 3, balls are 1" and 1.5"
still need to grind down the welds a little, sand, buff/polish, passivate...etc
http://i246.photobucket.com/albums/gg93/waggie51/machining/1-bar.jpg
http://i246.photobucket.com/albums/gg93/waggie51/machining/2-bent.jpg
http://i246.photobucket.com/albums/gg93/waggie51/machining/3-cut.jpg
http://i246.photobucket.com/albums/gg93/waggie51/machining/4-machined.jpg
wagnerite
01-09-2010, 09:57 PM
two more.
http://i246.photobucket.com/albums/gg93/waggie51/machining/5-welded1.jpg
http://i246.photobucket.com/albums/gg93/waggie51/machining/6-w-cd.jpg
lazlo
01-09-2010, 10:00 PM
Nice Tig welds. How did you hold and rotate the curved tapered section to do the welds?
vpt
01-09-2010, 10:02 PM
Looking good! Where did you get the balls from?
lugnut
01-09-2010, 10:04 PM
I would think for all the support you recieved on this project, we would get to see some photos of these toolsin action:eek: A video would be better
Mel
wagnerite
after tacking, just rotate it with left hand while right hand fuse weld. second pass was done like this, melt puddle, dip 4 times, then balance it and do another 4 dips of the rod... rebalance... so on
wagnerite
01-09-2010, 10:08 PM
this was the most difficult part of the project. the 1 inch balls are from a seller on amazon (named: smallparts). yeah, i know! of all places, amazon!
1.5" balls are from McMaster, they're actually 440 SS.
Mel
I APPRECIATE EVERY BIT OF ADVICE EVERYONE HAS GIVEN ME. :)
my wife has refused to be in the video, none of her friends will either. i guess its all up to me now. i made the thing, now i have to demo it. where's the camera....
doctor demo
01-09-2010, 10:13 PM
So far so good, are You going to post any pics of the tool being used?:D
How far below retail are You on the two You have shown?
I know someone that does passion parties for a living and I may consider making a line of products , I can't believe how expensive this stuff is.
vpt
01-09-2010, 10:15 PM
I actually just found the 316 balls on ebay. So now I have everything ordered for my own. Can't wait to tell the wife where I got the idea from! :eek: I am going to wait till I give her the present. She doesn't know anything yet.
lazlo
01-09-2010, 10:16 PM
It's like making sausage -- it's something you really don't want to see ;)
wagnerite
01-09-2010, 10:20 PM
its not for me, but if you want a pic of me demo'ing it, i suppose i can give it a go hahahahah.
$20 in on the materials per piece. i got enogh material to make 8 or 9 more. I can make 10 of these for $200 in material. they retail for $75-125 on the internet.
wagnerite
01-09-2010, 10:21 PM
you're such a pervert! ;)
vpt
01-09-2010, 10:24 PM
What are you talking about? This is a towel wrap holder isn't it? :p
wagnerite
01-09-2010, 10:30 PM
actually, its over a pound in weight. also, with majority of the weight in the large sphere end... if there were an intruder in the house, i think even a woman can swing this thing and seriously hurt, if not kill the intruder if it were struck in the head. :eek:
Carld
01-09-2010, 10:33 PM
:eek: well, I, uhhh, errr, nice work. Will you get to manipulate it when it is in use?:D
websterz
01-09-2010, 10:35 PM
Suddenly I'm in the mood to listen to a little Steely Dan...:D
wagnerite
01-09-2010, 10:38 PM
um, well, these sort of thing are made for solo-usage, i'm sure it can accommodate more then one participant :)
Carld
01-09-2010, 10:40 PM
Don't forget the adult drink to loosen the libido.
vpt
01-09-2010, 10:45 PM
When I ordered my spheres it said the 1.5" one was .51 pounds.
wagnerite
01-09-2010, 10:55 PM
sounds about right. the 1 inch ball weights less then half that, plus the shaft.. i used 5/8" was going to use 1 inch tapered to.... well, we won't get into that. this thing weights the same as my hammer, and nearly as long.
vpt
01-09-2010, 10:57 PM
I ended up getting 3/4" for the shaft. I will try to lathe a little piece to see how it goes. I don't think my atlas will fair well against the 316 though.
wagnerite
01-09-2010, 11:02 PM
i had no problem at all milling that little flat spot on the 316. the 440 was another matter. there were some sparks and light straw colored chips. i was milling away .001 to .003 at a time. once i slow down the feed, it cut fine.
JTToner
01-10-2010, 12:54 AM
In school we made balls from round bar, 303 as I recall, but the kicker is we did it on a BP. The method was to rotate the head to the right approx 35* (I could be wrong on the angle, this was three years ago). The round bar was held in a chuck mounted on an indexing head. The indexing head was mounted such that the bar stock was aligned with and centered to the BP's spindle. The indexing head was also tilted to the right maybe 30*, but I'm not sure of the angles. Setting them was trial and error. A single point cutting tool was installed into a holder not unlike a fly cutter but with the tool parallel to the axis of the BP's spindle. The balls were made by turning the crank on the indexing head to rotate the bar stock while the tool in the spindle was cutting the stock. Periodically, it was necessary to raise the mill's knee until the entire ball was completed. Sounds weird, but it worked. We made 18 balls about 1 1/4" in dia. for the ends of the spokes on speed wrenches for our vises. I have two of the wrenches and will try to post pics tomorrow. Maybe some gray-beards around here know of this method for making balls. It was kind of cool but not practical for production.
Johnny
winchman
01-10-2010, 01:18 AM
I think I finally figured out what they're for, but what are they called?
doctor demo
01-10-2010, 01:20 AM
Johnny
Johnny, was it a carbide tool or hss?I assume it was a form tool also.
doctor demo
01-10-2010, 01:28 AM
Roger, go to the locked thread and click on the link in one of the posts around page4.
beanbag
01-10-2010, 01:40 AM
Looks like a Klingon bludgeon device
JTToner
01-10-2010, 01:44 AM
Doc, the tool was HSS. Also, I just went to the shop and checked - the balls were not stainless, just 6061 (my bad), and are 1 5/16: dia. I'll post pics and details tomorrow in a new thread. Here, I just wanted to comment on the odd way we made the balls.
Johnny.
SDL
01-10-2010, 03:57 AM
Hope the recipients haven't seen this or they may think youve been wasting your time.
http://news.bbc.co.uk/1/hi/health/8439000.stm
Steve Larner:)
Machtool
01-10-2010, 07:11 AM
I've looked and looked and looked again for that thread.
Only one I could find was this.
Material Selection? Cast Iron and Steel for a Clapper Box
http://bbs.homeshopmachinist.net/showthread.php?t=38959
I'm sure thats not it.
Your Old Dog
01-10-2010, 07:23 AM
ROFLAMO! :D That's the funniest thing I've read on the board in ages!
Tony Ennis
01-10-2010, 10:30 AM
Dude, those welds better be glass-smooth.
MichaelP
01-10-2010, 10:43 AM
I'm afraid the shape may be a bit incorrect anatomically. Two additional slight curves are needed on both ends, IMHO.
RKW
01-10-2010, 10:57 AM
http://bbs.homeshopmachinist.net/showthread.php?t=38878
Your Old Dog
01-10-2010, 11:01 AM
I agree. Shape it like this one made out of brass.
http://www.mycokecancollection.com/wp-content/uploads/brass-coke-bottle.jpg
