today i was doing a bit of organizing (kinda) and ran across a couple 3/4" armstrong carbide lathe tools. can a guy just grind down the 3/4" steel and use these guys in a smaller holder or is there a problem with the carbides being too large ? and what is the tool on the left used for? actually i found about 4 of those. . . .
diggin in my stuff (what that?)
i did mill two of them down last night on my bridgeport using a carbide tipped single point tool in a cheapo flycutter. bang bang bang bang, every revolution. it did work, i needed to sharpen the carbide once but it still worked. maybe i should have used a ruffing endmill ? i have no clue. but i still have more to do.
why would i need to change the relief of the carbide ? i am just re-sizing the square of the tool.
these are painted grey, im guessing someone took them from the military a long time ago. they do say armstrong on them however.
on another note, i found a 1/2" "cobalt" stick cutting tool in the mess. nice and shiney. in researching cobalt, i read that its not solid cobalt but a small % added to the hss to make it a bit harder. is this true ? i have a good set of cobalt drills for removing broken allen head screws and stuff and they seem quite a bit better than just good drills. is there an advantage to the cobalt additive in lathe tools ?
davidh (the guy with many questions)
I've reduced these type of shanks often,but you must do a file test first.I never came across one yet that didn't turn out nice.I wish you well I have spent alot of money buying a nice set of kennametal tools which I am going to convert to using from now on along with the tools I have both with hss tools and those with carbide cutters soldered on may become redundant.Keep happy and well .AlistairPlease excuse my typing as I have a form of parkinsons disease
