View Full Version : Gear cutting, sums check please...
Davek0974
01-12-2010, 02:10 PM
Hi all,
I'm getting close to cutting my first set of gears, nice and small - 4DP :)
Machinery and clamping is all good to go, A&S 2E horizontal mill.
Can someone check my figures please?
Cast iron,
55 tooth gear,
blank is 14.25" dia,
using 4DP No2 cutter of 3-5/8" dia with 10 teeth,
82RPM (nearest suitable speed on mill)
90:1 ratio rotary table,
33 hole dividing plate, using 1 turn & 21 spaces per tooth index,
cutting full depth of 0.539" in one pass after gashing with a 3/16" side/face cutter almost to full depth.
something like .003" chip load?
Thanks in advance
Errol Groff
01-12-2010, 02:41 PM
Cast iron,
55 tooth gear,
CORRECT
CORRECT
OK, might be a trifle fast.
That is correct. Don't forget that when setting your sector arms for the 21 spaces DO NOT count the hole that the pin is in.
Feed = RPM x No. of teeth x chip load so 2.5 ipm feed
Davek0974
01-12-2010, 03:02 PM
Thanks, i have the question on another group and one reply has also said the speed is a tad generous, i''ll knock it back a bit.
I'll count the spaces between the hole the pinis in and the hole the pin will be in. I had to mak a new dividing plate of 38 holes for a 76 tooth gear and it all worked well so i'mon the right track.
Davek0974
01-13-2010, 02:48 PM
Update,
Ok, thanks for the advice, i've got it setup as in the pics below, seems to make sense and appears nice and firm. Just though i'd get a second oppinion before i pull the loud knob:)
Setup with gashing cutter in place...
http://xa.yimg.com/kq/groups/17605961/sn/85335625/name/DSCN1349.jpg
http://xa.yimg.com/kq/groups/17605961/sn/90490285/name/DSCN1350.jpg
http://xa.yimg.com/kq/groups/17605961/sn/1647992084/name/DSCN1351.jpg
The long stud with the washer on has a centering mark on it so i can change cutters easily.
