View Full Version : jmt 360x1000 lathe
wooleybooger
01-21-2010, 10:18 PM
anyone ever heard of a jmt360x1000 lathe? its actually a 14x40 gearhead with a d1-6 spindle,mt3 tailstock,inch/metric threading and footbrake. no chuck and no tools other than a 4-way toolpost. it looks good from the pics,is close enough to pick up and he has the only bid so far(noon Fri auction ends). from the minimal infi ive given,is this lathe a keep or pass? thanks,mike
whitis
01-21-2010, 11:36 PM
You might have had a little AM/PM glitch on ending time:
http://cgi.ebay.com/JMT-360-X-1000-Lathe-Tested-working-_W0QQitemZ250562102860QQcmdZViewItemQQimsxZ2010011 6?IMSfp=TL100116234003r1920
Black_Moons
01-22-2010, 01:20 AM
lol can't even sell a lathe for 99 cents...
Nice giant shield on the carriage.. boy those would be useful when turning with carbide and those red hot meteroids start falling all over the shop.
I wonder what the 4th control rod along the bed is... I know the first 3 are leadscrew, keyed feed rod, and forward/reverse/stop selector..
The Artful Bodger
01-22-2010, 02:17 AM
Maybe it is a seperate feed rod so that cross feed and carriage movement can be adjusted seperately. Maybe it is a feed for auxiliary stuff on the carriage, an auxiliary spindle or even a tool post grinder! I really dont know but 99c seems quite a bargain, almost worth it just to solve the puzzle.
It is made by Jinan First Machine Tool works and seems like a current model. Specs:
MT360:
Features:
High accuracy, low noise, extreme rigidity, JIS Standard of Japan and CE standard.
Metric, whit worth, Module and D. P threads.
Suitable for various kinds of shafts, sleeves and disk-type work pieces.
Accepting special orders such as voltage, frequency, speed etc.
Protective device of overload, to guarantee safety.
Foot-braking device, for high efficiency and safety.
Max. Swing over bed: Φ360mm
Center distance: 570mm/ 1000mm
Max. Swing over carriage: Φ210mm
Max. Swing in gap: Φ500mm
Range of speed: 76-1500/2000 (rpm)
Bore in spindle: Φ40mm
Max. Traverse of compound rest: 100mm
Spindle motor: 4KW
Machining accuracy: Roundness (0.002-0.006)/ Roughness (1.6)
Mark McGrath
01-22-2010, 02:25 AM
Chinese I think.Made by Jinan?
Mark.
The Artful Bodger
01-22-2010, 02:43 AM
Mark.
I believe you are correct!:)
It is a Mazak Mate clone...A hell of a good design but how good the JFMT build is I do not know, but I see quite a few larger JFMT lathes around the place..
I would not rate JFMT machines as low end Chinese...
Here is a genuine Mazak http://www.machineryvalues.com/14-Engine-Lathe-Mazak-1440-Mate-Inch-Metric-Gap-p/143332.htm
wooleybooger
01-22-2010, 09:20 PM
thanks,guys. the info i posted was from my friends memory. after i made this post he called with the e-bay info. i looked it over and could have sworn it had approx 22 hrs left. when i looked a short while ago,it showed auction ended with no bids. i dont know if he won or not. it did look like a pretty good machine,use and abuse wise. mechanically,who knows? again,thanks.mike
