View Full Version : Help finding a US distributor
hwingo
01-25-2010, 06:51 AM
Attached are two images of IEC breakers (switches) for my lathe. The DZ47-63 is thought to be a 16 AMP breaker (switch) and I need a minimum of 20 AMPS.
The DZ47-60 is believed to be a 2 AMP breaker (switch) and I need a minimum of 3 AMPS. Where in the US can I find a source/distributor for these brand breakers/switches?
http://i234.photobucket.com/albums/ee38/hwingo_2007/LatheBreakerSwitch1.jpg
http://i234.photobucket.com/albums/ee38/hwingo_2007/LatheBreakerSwitch2.jpg
PixMan
01-25-2010, 07:28 AM
I think it would be much easier to replace them with a more-common Omron (or other popular make) version. You can measure the physical dimensions and cross-over.
RobbieKnobbie
01-25-2010, 08:06 AM
I'm really curious why they have to be exactly the same brand? Breakers are a fairly standard commodity part and made by just about everybody.
Try www.automationdirect.com, they have a pretty good line and very good prices, and they don't mind selling onsie-twosies to folks like us.
hwingo
01-25-2010, 08:19 AM
They don't have to be the same brand as long as they are a suitable substitute. My definition of "suitable substitute" is for them to be "plug & play" ..... no modifications needed and the correct amperage. Simply remove what I have and snap the new ones in place.:)
millwrong
01-25-2010, 08:31 AM
They appear to be DIN rail mounted. As stated, any breaker that meets your needs, and code, that mounts on a DIN rail.
EVguru
01-25-2010, 08:37 AM
Yes, standard DIN rail mounting breakers.
http://en.wikipedia.org/wiki/DIN_rail
The 'C' is the delay curve rating (A, B, C, D, etc.) and you need to match that too.
hwingo
01-25-2010, 08:49 AM
Hi Guys,
Thanks for the replies. This gives me more to go on. Sadly, I know nothing about substitute parts. With the information that's been provided, I will reengage my search. Just maybe I can provide enough information to local electrical shops so that they might come up with an acceptable substitute.
Harold
darryl
01-25-2010, 11:33 AM
Seems to be a bit of a tolerance spec on that dual breaker to the left. Zero point off. :)
Glenn Wegman
01-25-2010, 11:51 AM
My lathe uses similar DIN mounted line breakers and they are made by Siemens.
Glenn Wegman
01-25-2010, 12:13 PM
Harold,
Allied Electronics has them...
http://www.alliedelec.com/catalog/pf.aspx?FN=1182.pdf
RobbieKnobbie
01-25-2010, 05:47 PM
Here's the single pole...
Single Pole C2 breaker (http://www.automationdirect.com/adc/Shopping/Catalog/Circuit_Protection_-z-_Fuses_-z-_Disconnects/UL1077_Rated_Supplementary_Circuit_Breakers/Single_Pole_Circuit_Breakers_(WMS1_Series)/C_Curve_(WMS1Cxx)/WMS1C02)
And here's the dbl pole...
Dbl pole C16 (http://www.automationdirect.com/adc/Shopping/Catalog/Circuit_Protection_-z-_Fuses_-z-_Disconnects/UL1077_Rated_Supplementary_Circuit_Breakers/Double_Pole_Circuit_Breakers_(WMS2_Series)/C_Curve_(WMS2Cxx)/WMS2C16)
Pretty cheap too.
hwingo
01-25-2010, 09:16 PM
Harold,
Glenn, and RobbieKnobbie,
I just got home from work and read the remaining post.
Thank you VERY MUCH for finding those places. This has been a GREAT help. Also, thanks Paul for explaining the meaning of "C". This too has been a GREAT help.
Many thanks to ALL poster for helping!
Harold
