View Full Version : universal joints
duckman
02-01-2010, 01:00 AM
Why when I go looking for a needle bearing u-joint with 3/4" X 5/8" bore there are none available 3/4" and up no problem. :confused:
tdkkart
02-01-2010, 01:16 AM
Check the stockcar and street rod places, I see Sweet mfg makes a 3/4 smooth x 5/8-36 spline joint. Grab one of these and skim the splines out of the 5/8" end.
http://www.speedwaymotors.com/Steering-U-Joints-5-8-36-Spline-Vega-Corvair-GM-Rack,31387.html
winchman
02-01-2010, 06:30 AM
You might look at the joints used on some steering shafts. I used one from a Ford of some sort on a project a couple years ago. I think the bore was 5/8".
