View Full Version : Collet chuck
digr
02-05-2010, 04:25 PM
I had a set of collets for the mill and wanted to use them on the lathe.
Boss is cut and sand blasted
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/bosscut1.jpg
Bored and threaded
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/boring.jpg
test fit
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/Testfit3.jpg
Collar turned around and bored for press fit of nose piece
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/4-1.jpg
digr
02-05-2010, 04:32 PM
More pics
beveling for weld for nose piece
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/beveling5.jpg
3" stock is cut to length
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/cut1.jpg
Faced and turned for press fit into collar and beveled for weld
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/turn2.jpg
Pressed together
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/press3.jpg
digr
02-05-2010, 04:39 PM
ready to weld
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/ready4.jpg
welded
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/welded5.jpg
Faced and od turned. I left the unturned part so I could use a pipe wrench to take the part off when needed
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/sturn1.jpg
threaded
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/thred2.jpg
digr
02-05-2010, 04:44 PM
drilled
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/drill3.jpg
setting compound to cut taper
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/taper4.jpg
cut off a drill extension so it would fit into my die grinder to grind the taper
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/1.jpg
drill extension done
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/2.jpg
digr
02-05-2010, 04:49 PM
grinding
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/3.jpg
holes for spaner wrench, should have been slots instead of holes, holes are hard to find:D
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/4.jpg
Thats the end of the story. I was impressed with the outcome. 0 runout at the collet and .002 6" out. All I have left to do is to make a spaner wrench.
http://i961.photobucket.com/albums/ae96/digr/collet%20chuck/HPIM0188.jpg
DICKEYBIRD
02-05-2010, 04:53 PM
You made that look quick and easy. Great job!:D
digr
02-05-2010, 05:03 PM
Thanks I was ascared to try it at first but it turned out excellent and I use it more and more all the time:D
ptjw7uk
02-05-2010, 06:51 PM
Hi digr Why did you make it in 2 parts and weld together or am I missing something!
Still nice job.
Peter
digr
02-05-2010, 07:35 PM
Still nice job.
Peter
Thanks I didn't like the idea of threading into a blind hole. I guess I could have run in reverse and and thread out but I felt more comfortable making it in two pieces, plus I am a welder not a machinist I just pretend to be one on weekends.:D
Ken_Shea
02-05-2010, 10:28 PM
Well that qualifies you as both machinist and welder,
Just a dang fine job!
Doozer
02-05-2010, 10:33 PM
"I didn't like the idea of threading into a blind hole".
Get a 2" travel dial indicator.
Mount it to the bed with a clamp or a magnet.
It makes boring or threading into blind hole not scary at all.
--Doozer
