View Full Version : SB9C question
10-23-2003, 12:01 AM
I was cleaning all the wood chips out of my lathe and took the top slide off. I haven't had it off in some time. I noticed a couple of nice 5/16x18 bolt holes in the cross slide. I looked in my original exploded view parts manual and they are not shown. Anyone know what they are intended for? Looks like a handy place to attach a simple milling attachment.
http://vts.bc.ca/img/cross1.jpg
JCHannum
10-23-2003, 10:02 AM
Somebody had an attachment of some sort there at one time. Looks a little too close to center to be good for milling attachment.
shaque
10-23-2003, 01:44 PM
EVAN
I checked my SB9 and found the same thing as you did, so obviously, they were made that way for some reason or other http://bbs.homeshopmachinist.net//biggrin.gif
Jim http://bbs.homeshopmachinist.net//smile.gif
JCHannum
10-23-2003, 02:45 PM
The South Bend milling attachment appears to bolt on with two bolts on a diagonal pattern that is on a wider bolt circle.
Holes that close in would not permit it to swivel.
Check the pics in the How to Run a Lathe book. Don't see any other attachments that would use them.
10-23-2003, 04:15 PM
Those holes will be perfect for what I want to do. More later.
Herb W
10-23-2003, 08:47 PM
I skimmed through a copy of a SB lathe 'attachments' brochure (think I downloaded it from the sb yahoo group)
Apart from some sort of milling attachment, the other possibility that I came across was a 4 way turret toolpost which mounts directly to the cross slide. Couldn't tell from the picture if it would use the bolt holes or not.
SB made some nifty gadgets - some for the larger lathes only, but many for the 9" as well.
For instance - lever operated rack & pinion 'production' cross slide with front & rear tool posts -then just add the bed mounted turret attachment and presto...mini turret lathe...could be a real time saver for making quantities of small parts, batches of non-standard fasteners etc.
Some others - 4 position carriage stop - 4 position cross slide stop - lever operated tail stock...potential projects to add to 'the list'?
alcova
10-23-2003, 10:26 PM
I have one of those SB 4 ways and mine does not use any extra holes for mounting it down...I just remove the cross slide and mount in in place
Walt
10-24-2003, 10:38 PM
South Bend did make some attachments for automotive repair which included among other things a fixture that mounted in place of the topslide for boring babbit lined conrods maybe this is what they are for?
Arcane
10-25-2003, 01:08 AM
My 9" SB has an identical pair of holes in the cross slide.
10-25-2003, 01:19 AM
The plot thickens...
shaque
10-25-2003, 11:39 AM
Hello Southbend, are you out there??? http://bbs.homeshopmachinist.net//biggrin.gif
thistle
10-25-2003, 05:15 PM
i have the attachment it consists of a rectangular piece of steel with a 0.75 inch hole through it and two bolts.
you attach it and then can lift the lathe up with a chain hoist mounted over head to clean underneath it.
JCHannum
10-25-2003, 06:25 PM
I would not recommend lifting a lathe by the cross slide.
John Stevenson
10-25-2003, 07:37 PM
<font face="Verdana, Arial" size="2">Originally posted by thistle:
you attach it and then can lift the lathe up with a chain hoist mounted over head to clean underneath it. </font>
Is this on the first of April every year??
John S.
10-25-2003, 11:40 PM
Thistle,
Not a bad idea! It would be really easy to balance too. Just crank the carriage until it is balanced. I'll have to try that.
Oh yeah, I guess I should tighten the gibs really well first.
Filled a garbage can with chips today http://bbs.homeshopmachinist.net//biggrin.gif
[This message has been edited by Evan (edited 10-25-2003).]
Herb W
10-26-2003, 12:28 AM
Lets see, bolt on the attachment, then lift the lathe with a chain...
Oh yeah, now I remember...it's the 'boat anchor' attachment...
