View Full Version : grinder ideas plx
Tony Ennis
02-10-2010, 07:55 PM
I have a common 6" Delta grinder. It sports two rests, one for each wheel. These rests are literally about 1.5" square.
What do all the cool people replace these with?
daveo
02-10-2010, 08:23 PM
Take em off and throw them away :)
DICKEYBIRD
02-10-2010, 09:34 PM
You can make yourself one of the talented Mr. Ishimura's adjustable grinding rests. Here's mine.
http://i57.photobucket.com/albums/g227/DBAviation/GrindingRest3.jpg
Mcgyver
02-10-2010, 09:44 PM
mostly i'd agree with that. There are some jobs where support is nice, like grinding a round end profile tool....otherwise tool bits are ground free hand, its easier imo
bvd1940
02-10-2010, 09:51 PM
What he said, been doing it that way for years but what do I know:p
Bill snow birding in rainy AZ
Tony Ennis
02-10-2010, 10:21 PM
I had no idea.
gwilson
02-10-2010, 10:29 PM
Grinding mine free since 1959.
Carld
02-11-2010, 12:08 AM
I usually just swing them down out of the way. I used to grind all my HSS and brazed carbide free hand, no rest. Now I use my HF tool grinder for the carbide and free hand the HSS.
02-11-2010, 12:15 AM
I don't find 3-D free-hand grinding to do nearly as good a job as 2-D free-handing on a rest. With the rest, I can set the relief angle and concentrate on the shape in the other 2 dimensions.
I put a piece of 1/8" steel plate on top of the stupid little "table", one that was big enough to at least fit an HSS blank on it.
Jim Shaper
02-11-2010, 12:56 AM
I thought that shelf was there to collect grinding dust and tell you when your wheel had worn down. Now you tell me it's to hold stuff on? Who knew... :p
tdmidget
02-11-2010, 07:23 AM
One thing it does it get you a fine from OSHA if it's missing or more than 1/8 inch from the wheel.
Circlip
02-11-2010, 07:56 AM
If you can obtain/look at a copy of "Tool and cutter sharpening" by Harold Hall in the "Workshop Practice Series" - British publication, Harold describes the build of a jig similar to the one shown but with additional parts to expand its use on the bench grinder.
Regards Ian.
And if you can locate it, a series of articals by "Duplex" starting in the October 1948 Model Engineer headed "In the workshop" 21, a cutter grinding attatchment.
CountZero
02-11-2010, 08:38 AM
I can recommend Harold Halls book also, received it yesterday and could hardly put it down until I had read all of it..
In the "Tool and cutter sharpening" he describes one rest with a lot of attachments, for example drill sharpening and end mill sharpening. He describes a bit more advanced rest in his book "Milling, a complete course" but I dont have that one so I can't comment..
Here is is site: http://www.homews.co.uk/
lane
02-11-2010, 07:25 PM
Here is what I use on mine.
http://i178.photobucket.com/albums/w277/lane5263/grinder/grinderpict001.jpg
and one for carbide
http://i178.photobucket.com/albums/w277/lane5263/grinder/grinderpict002.jpg.
These may be some ideas.
MTNGUN
02-11-2010, 09:34 PM
Lane, I like your design. Thanks for sharing.
