Hello all,
I am going to try and make a die set to punch out some loop type, flag style electrical connectors (1940's automobiles.. not available) for 8 to 16 guage wire and terminals of approx 3/16 1/4 inch.
Since this is a test run I am figuring on using A2 for the punch, and 'steel' (whatever is around) for the die (which will be case hardened - kasenite). Since the parts is a small connector I figure that any 1/2in plate should be able to take a few tons to punch the metal... maybe 1/32 or 3/64ths thick.
I have read that dies are (re)-'sharpened'.. dies that mean a clean 90deg angle on the punch?
The legs that wrap around the wire are pretty long and thin... can I expect this to be the most trouble? Would doing two operations help or hurt the chances of getting the 'legs' right?
Thanks for any advice.
