View Full Version : this is crazy is it not?
Alistair Hosie
02-21-2010, 03:22 PM
Mark Jones alias aboard epsilon kindly bought me a bunch of 3 phase plugs and sockets which I paid him for .I thanks him for his kindness anyway I am adding a few more machines and I rather than bothering Mark ordered from ebay identical plugs male 2 of at 14 from ebay anyway one of them arrived and guess what it is identical in everyway exept it's too big Mark could you tell me yet again where you got them sorry to be a nuisance but I will have to order some more of the correct size my question is why do they make red identical plugs in 2 different sizes all pins are the same configuration as said colour is the same.I don't understand this dioesn any one else and are they able to explain this.Alistair
John Stevenson
02-21-2010, 03:32 PM
Because they are different ratings.
The smaller is 16 amp per phase and the larger are 32 amp per phase.
The number 16 or 32 is usually in the description. What was the Ebay number
http://cgi.ebay.co.uk/3-PHASE-PLUG_W0QQitemZ330405967157 is a 32 amp plug, big one.
310202386506 is a 16 amp 5 pin
250476197045 is a 16 amp 4 pin
MrSleepy
02-21-2010, 03:40 PM
There is quite a range to choose from sized by current an number of pins..
http://cpc.farnell.com/jsp/search/browse.jsp?N=411+500001+1001644&Ntk=gensearch_003&Ntt=415v+plug&Ntx=mode+matchallpartial
if you scroll down you may recognise the ones you need..
Rob
aboard_epsilon
02-21-2010, 03:43 PM
The ones i got you were 16 amp
The ones you've just got, must have been 32 amp
The make you are after which in my opinion is the best.............look at the initials of the make of the one you have already three initials beginning with P.......or you could end up with one of the old fashioned ones that are difficult to wire up.
edit ...the good ones are made by PCE in Austria
i cant understand why there isn't any electrical wholesaler up there where you live.
i get mine from another wholesaler now ...nearer
http://www.electricalwholesalesupplies.co.uk/
the place were i got them from before was GDR electrical ltd deeside industrial estate , flintshire
they have now changed their name ..cant remember what it is now ..but phone number still the same
which is :-
01244 289343
the 16 amp 4 pin should be about 3.50 -5.50
all the best.markj
John Stevenson
02-21-2010, 03:58 PM
http://cpc.farnell.com/pro-power/pe1664sva/plug-16a-ip44-415v/dp/PL08942
2.49 each from CPC if you want the 4 pin.
Alistair Hosie
02-21-2010, 04:03 PM
Yes Mark 32 amp I didn't realise they would be different sizes because the ampage rating was different.That's my mistake then ignorance is generally costly :D I bought them from these guys Thanks again mark this time I will print out the companies name:D listair
http://cgi.ebay.co.uk/415V-32A-4-PIN-PLUG-RED-GARAGE-WORKSHOP-3-PHASE-32-AMP_W0QQitemZ120529770775QQcmdZViewItemQQptZUK_BOI _Electrical_Components_Supplies_ET?hash=item1c1022 5917
aboard_epsilon
02-21-2010, 04:06 PM
Thats the old fashioned one John ..
the ones i got him have a cable grip gland on the end that twists and locks an iris .
the plug is also in two halves that twist and lock together .
all the best.markj
Alistair Hosie
02-21-2010, 04:33 PM
To Be fair the ones Mark got me were and still are fabulous I just wish I/we mark had made the bank bigger it takes eight female sockets all filled with tools and overflowing.Thanks guys so far.Alistair
