View Full Version : aciera drill
entoffice
10-26-2003, 10:23 PM
i recently obtained an aciera precision drill press which uses schaublin 6mm collets-does anyone know where these can be found
Ragarsed Raglan
10-27-2003, 09:11 AM
ent,
Schaublin collets (W Series) are usually described as the shank diameter. Such that a W12 collet has a 12.0mm diameter shank, is 44.5mm overall length, with a 16.0mm head diameter. Collet front angle is 15* with a 0.461" x 1.25mm Buttress thread. these are available upto a maximum 8.0mm dia. grip. Other collets in the W series range are W20, W25, and the odd named W31.75!!
I wonder if the shank diameter of your Aciera drill collet is 6 mm then you may need a Lorch style collet, details are:-
Shank 6mm dia.
30.0mm O/length
10.6mm head dia.
20* 30' head angle
5.0mm x 0.7mm P Drawbar thread
0.5mm to 5.0mm capacity range
Please confirm your collet size and we can find exactly what you need.
RR
entoffice
10-27-2003, 03:48 PM
it is definitly a schaublin collet because it has the SA logo but it has the dimensions of the lorch collet you descibed
Ragarsed Raglan
10-27-2003, 05:03 PM
ent,
This is a 'Lorch' collet manufactured by Schaublin then. The Einheit number for this collet is 304E. It is currently available new from
Crawfords Collets
Tower Hill Works, Witney
Oxfordshire
OX8 5DS, England
Tel +44 1993 703931
or email: sales@crawford-collets.co.uk
Their Cat ref. for this collet is #2801 range of sizes are 0.5mm to 5mm (these collets DO NOT collapse down and can only be used for their stated diameter)
They'll cost about £20 ($34USD) each.
For second hand collets try an advert on the 'Private Ads' of the following website:-
http://easyweb.easynet.co.uk/~chrish/homepage.htm
Come back if you have no luck as I might know of some other places to try.
RR
entoffice
10-29-2003, 12:05 AM
<font face="Verdana, Arial" size="2">Originally posted by Ragarsed Raglan:
ent,
Shank 6mm dia.
30.0mm O/length
10.6mm head dia.
20* 30' head angle
RR</font>
collet size is 6mm
entoffice
10-29-2003, 12:19 AM
ent,
Crawfords Collets
Oxfordshire
OX8 5DS, England
Tel +44 1993 703931
RR
</font>
thank you for your help
