JCHannum
03-22-2010, 09:42 PM
The Lyman Tru-Line Jr turret press was popular in the 50's. It is a light weight four station press. It is a capable press, but it uses an obsolete die with 5/8"-30TPI threads.
I picked up one at a gun show over the weekend and decided to make a new turret that will accept the more readily available 7/8"-14 dies. They fit up with little problem on the same centers, the turret just needs to be a bit larger in diameter. I used a 4" X 1" thick slice of steel, machined to fit and drilled and threaded on the mill & rotary table.
http://i320.photobucket.com/albums/nn351/jchannum/P1070602.jpg
These presses show up at shows and on eBay frequently and can usually be had for a few dollars. The only negative is no primer feed, it is manual and the shell holders can be missing. I got several holders with the press, but will take a pass at making an adapter to take standard holders. There is enough room and that also looks like a straight forward lathe job.
