Buckshot
03-25-2010, 01:30 AM
My neighbor has a buddy with one of the AMT 30 carbine semi auto pistols, whose rear sight had parted company with the slide. My friend asked if I could make him a new one and he'd pay for it. I said I probably could but I doubted I'd be able to make it windage adjustable, and to myself I thought I really didn't want to make it at all :-)
http://www.fototime.com/1A872A74808D1F2/standard.jpghttp://www.fototime.com/CBD46B9034D6CCE/standard.jpg
I hadn't thought to take any pics when first starting the project, and the one on the left of drilling the roll pin hole was the first. The slide was already drilled for the pin so I naturally used it for the guide. The right photo is after drilling and shows the sight as I'd had it done to that point.
http://www.fototime.com/F4D30F3D7415969/standard.jpghttp://www.fototime.com/49A4C5F1F74E688/standard.jpg
Another couple photo's of the raw rear sight as machined to that point and having cross drilled for the retaining roll pin. On the right the sight has now been drilled for the elevation adjusting screw.
Part 2 below:
Part 2 below:
