davidh
03-28-2010, 10:53 AM
I have a motor driven power hammer machine called a pullmax. It has a 4 speed transmission on the back end of the motor and had a large box also controlled the 4 speed transmission with a switch / button interlock control box wired in to the momentary contact “start / stop” buttons. The interlock unit would not allow the motor to start unless the transmission was in a selected gear, nor allow the transmission to be shifted unless the motor was completely stopped.
This is old relay / limit switch technology and one of the shift control motors was burned out causing many of the wires in this unit to melt or burn off completely. . .
I have removed the assembly and intend to simplify the shifting and starting with just a couple momentary contacts witches and manual controlling of the gear changes. The problem im having is with the magnetic motor starter and its wiring. Does the term “latching relay” come into play here ?
I can make the motor start and run using a wooden wedge to lift the relay latch and hold it in place. I can also get the relay latch to make the motor start by momentarily connecting 110 volts to it but when I remove the 110 volts, the latch of course releases and the switch opens up, causing the motor to quit. Somehow the latch must be powered so a momentary contact start button will electrically lift the latch but what or where does the power come from that holds the latch in place until another momentary contact stop button breaks the circuit and will cut the power to the motor ? is that another 110volt wire thru the two momentary contact stop / stat buttons ? these start / stop buttons are n/o and n/c now as they were prior to my removing everything that they controlled.
I have taken a couple pictures of the magnetic motor starter (relay) assembly and the 4 small connections in the center of the photo are the ones in question. The top left hand connection (labeled 2) has a 110 volt supply wire already attached but from there I assume I must run a wire from the right hand connection (labeled 3) to the start button that’s n/o. that will raise the latch and the machine runs until I take my finger off the start button.
http://i260.photobucket.com/albums/ii12/tooldoc/19.jpg
The two screw connections with the 110v 60c tag between them (below 2 & 3 )are possibly the holding circuit but I don’t want to even attempt putting power to them until I know I won’t burn up anything.
Can anyone with electrical knowledge tell me if im thinking along the right path ?
Simplified it would be a latching relay, using a combination of a n/o and n/c pushbutton assembly and a bit of simple circuitry between them. . . ? ? ?
Thanks very much.
Davidh (knowing just enuf about this to be dangerous)
Thanks very much.
