View Full Version : cleaning white powdery gunk off pot metal parts
metalmagpie
04-10-2010, 07:16 PM
I'm rebuilding a motor. Several parts are cast from zinc or maybe aluminum. They are bolted to the steel shell of the motor's stator. They all have a lot of powdery white residue which I assume to be some form of zinc oxide. I'd love to find a way to soak this stuff off, as it is way down in tight corners and I don't have access to a bead blaster at present. I haven't had good luck with zinc parts in a lot of hot cleaning baths like lye/water or dishwashing detergent/water or TSP/water. They all seem to dissolve the zinc, some faster than others admittedly.
Short of bead blasting or vibratory tumbling is there a good way to get this junk off my parts?
metalmagpie
Forrest Addy
04-10-2010, 07:33 PM
vinegar .
