View Full Version : 1904 International cylinder head part 1
bob ward
04-11-2010, 10:27 AM
There doesn't seem to have been many pictures of people's oddball projects of late so I thought I would remedy that.
This is the cylinder head from a 1904 International 5" bore single cylinder stationary engine. The engine had recently been assembled and got running after sitting as a pile of parts for the last 35 years. The mating surface of the barrel is as rough as that of the head, so not surprisingly there were water leaks, even with double gaskets and lots of gunk. I offered to face the head to see if that stopped the leaks.
http://i237.photobucket.com/albums/ff28/sirrobertthegood/1904%20International%20cylinder%20head/IMG_0005-1.jpg
The head is 8" diameter and 4" thick, it should fit in the 4 jaw on my 14 x 40. BUT that inlet valve guide sticks out 50mm and isn't going to come out any time soon, so the head she no fit in the 4 jaw. Bugger, it will have to be a rotary table job.
http://i237.photobucket.com/albums/ff28/sirrobertthegood/1904%20International%20cylinder%20head/IMG_0004-1.jpg
First job is to check that the top of the head is reasonably flat, so out with the piece of tombstone and the 47 x 14 round blocks. From a previous life I have squillions of 20 x 47 x 14 bearings and metres of 20mm bright round to mount them on. I cut some of the bright round to keep the little bearing stacks orderly, and also through drilled them for a 12mm hold down bolt.
http://i237.photobucket.com/albums/ff28/sirrobertthegood/1904%20International%20cylinder%20head/IMG_0011-2.jpg
Turn the whole lot upside down on the granite, and it sits there nice and solid, there is no perceptible rocking. The top of the head is hereby declared to be a true surface.
http://i237.photobucket.com/albums/ff28/sirrobertthegood/1904%20International%20cylinder%20head/IMG_0007.jpg
alcova
04-11-2010, 04:40 PM
Interesting thread...please keep us informed
TGTool
04-11-2010, 10:04 PM
Boy, that last picture looks like something that would wake up and start walking across the bench when the moon is full! I'd put a hobble on it before I leave it alone in the shop at night. :eek:
ADGO_Racing
04-12-2010, 12:48 AM
Why not just mount it to a face plate now that it has legs? rather than playing around in the mill? Just a thought.
ADGO_Racing
04-12-2010, 12:50 AM
Or....Remove the intake valve guide, as it looks pretty beat. It appears to be cast iron, so just machine up a new one.
