View Full Version : anyone able to offer advice/help with this lathe
Alistair Hosie
04-12-2010, 09:51 AM
I have several woodworking lathes inc a Delta midi wood lathe with a ribbed belt which is looking severlt worn .I don't know were to get one of these does Delta still exist anywhere? also how do I go about taking the little headstock apart when I get a belt anyone who has done this please let me know.Alistair
http://www.cpowoodworking.com/wood_lathes/46-455.html?ref=nextag46-455
Alistair Hosie
04-12-2010, 12:01 PM
OKay I have taken the headstock spindle apart was quite straightforward and the returning of the spindle etc is or will be ok too I imagine .So now I need a 25 inch 8mm wide belt with 3 continuos ribs runing vertically longways anyone think of a place nearer to home other than Delta which seems to be defunked in the uk anyway.??? Alistair
doctor demo
04-12-2010, 06:23 PM
Alistair, Your link won't load for Me. Maybe it's just busy, I'll check later.
I can check the local Wood working tool store if You can't find anything on Your side of the pond if You'd like.
John Stevenson
04-12-2010, 06:35 PM
You want a 630 J3 Poly vee belt, ring your nearest bearing stockist.
