View Full Version : MK5 arbor question
Black Forest
04-15-2010, 12:31 PM
I have this mk5 arbor for my horizontal mill. I am not sure what type of tool would be mounted on it. Any idea's?
http://i853.photobucket.com/albums/ab91/burnandreturn/mk5_3.jpg
http://i853.photobucket.com/albums/ab91/burnandreturn/mk5_2.jpg
http://i853.photobucket.com/albums/ab91/burnandreturn/mk5_1.jpg
Timleech
04-15-2010, 01:04 PM
A shell end mill or an indexable insert facemill.
Tim
Machinist-Guide
04-15-2010, 01:36 PM
The arbor is for one of these They are called Shell Mills or Face Mills and come in a verity of diameters.
http://i766.photobucket.com/albums/xx310/Machinist-Guide/shellmill.jpg
Here is a link to a video of a Shell Mill (http://www.machinist-guide.com/machining-rake-angles.html)
Black Forest
04-15-2010, 02:09 PM
thank you for the answers. Can I assume the four tapped holes would be to help secure a very large facemill and not just use the center tapped hole?
The outside diameter of the arbor is 90mm and the smaller shaft is 40mm.
DannyW
04-15-2010, 02:34 PM
Black Forest,
Your assumption is correct.
Regards,
Danny
