View Full Version : old lathe motor rpm
Tony Ennis
04-15-2010, 02:07 PM
My Craftsman 12" didn't come with the original motor (came with a 3hp Baldor - with tragically worn bearings)
I got a 1/2HP 3ph motor on it now. This motor runs at 1725 or 1750. The lathe seems to have low RPMs, not that this is entirely bad.
Anyone know the RPMs of the original motor?
coldformer
04-15-2010, 02:44 PM
1725 rpm you should have 28 rpm's in backgear
Tony Ennis
04-15-2010, 02:50 PM
Cool, thanks. I assume that's with the belts in the 'slowest' settings.
coldformer
04-15-2010, 02:53 PM
yes smallest groove and back gear engaged
Forrest Addy
04-15-2010, 02:54 PM
1/2 HP is on the puny side for your 12" Craftman lathe. Use it but keep your eyes open for a larger replacement.
Tony Ennis
04-15-2010, 03:04 PM
The Craftsman came with a 1/2HP single-phase originally, I believe. I might have a 1hp 3ph sitting around.
digr
04-15-2010, 06:54 PM
If there is a pulley speed chart on the lathe you can figure the motor speed.
