View Full Version : drill rod
fortcollinsjerry
04-16-2010, 06:39 PM
at what point does drill rod melt? I've been told that CRS starts throwing off sparks at 1500.
Isn't there a way to tell the difference by watching what kind of sparks each type throws off on a grinding wheel?
Optics Curmudgeon
04-16-2010, 07:40 PM
I was once given a pile of centerless ground steel rod, 1/8" to 1/2" diameter. I was told some was drill rod, some was the sort of slightly case hardened shaft places like PIC design sells. To tell the difference I just heated the end of each red hot and quenched them, a file quickly showed which was which.
Joe
