Belt Sander Radius adapter
  • gary hart
    • Nov 2003
    • 317
    Found in the stainless steel drawer while looking for something else.
    A double end "bone spoon” that guess is used by surgeons.
    Cut the tool in half.
    Milled out a pocket out of hunk of steel, bottom of pocket has big opening for crap to fall out but still have a stop for tool to only go in so far.
    Welded this to back of belt sander platen.
    Gave a quick try on edge of some aluminum and seemed to work good. Should be able to use small section of worked over pipe welded to some bar for making a different radius.
  • danlb
    • Nov 2008
    • 7994
    #2
    Very clever.
    Another trick to add to the toolbox
    Dan
