View Full Version : OT:access to Mach 3 pdf documents
Sophiedoc
04-18-2010, 09:26 AM
Recently Acrobat(legacy)on windows 98 not working because of missing dll files all of which I have been unable to replace.Old non used IE was recently removed.New editions of Acrobat require Windows reinstall which I hesitate to do.Foxit won't open.Would renaming files or other options work?
04-18-2010, 12:24 PM
What version do you have?
I have several older versions around, why I am not totally sure, and may have one you can use. Whether they can be sent without every virus filter in the world lighting up I don't know.
be aware that old Acrobat does NOT read current files correctly in all cases. But if you just need access to particular ones, you can be fine.
Sophiedoc
04-18-2010, 07:22 PM
Appreciate the offer but there must be a way to open these files with another reader by renaming etc.This works with other files.I know there are some file converters but there must be a simpler way since these are simply pdf files with an adobe label.
MrSleepy
04-18-2010, 07:49 PM
legacy versions can be got here
http://get.adobe.com/uk/reader/otherversions/
Rob
Sophiedoc
04-19-2010, 07:29 PM
The legacy adobe reinstall did the trick.For some reason Foxit doesn't seem as legible on my old computer-thanks.
