View Full Version : ATTN VP IT department
04-19-2010, 09:47 AM
I found a solution to a problem that I experience on a very regular basis when navigating in this forum. Many times after a long timeout I receive an HTTP error:
Error:
Bad Request
Your browser sent a request that this server could not understand.
This is the solution to the problem:
Symptom
Error:
Bad Request
Reason:
You're speaking plain HTTP to an SSL-enabled server port.
Audience
Host, ISP, or Systems Administrator
Solution
Some of the steps required to resolve this issue need a level of server access that will not be available to most end users. If you are a end user experiencing this problem, you may have to forward this information to your Host, ISP, or Systems Administrator.
This only happens when running suexec on a Linux based system. The cause of this is that the host does not have https in the safe_env_lst.
The host will need to look in the suexec.c for the section called safe_env_lst. Simply add https to these safe environment variables and recompile the file.
George Bulliss
04-19-2010, 09:54 AM
Thanks Evan,
Iíll move this along to the IT department. Be patient though, we are not high on the ITís list of priorities.
George
