View Full Version : making a lathe mandrel
jb-mck
04-22-2010, 09:22 AM
I have a couple of questions about making a lathe mandrel or morse taper. First, is O1 rod a decent choice of material? Second, Do I turn the shaft to size, then harden or do I leave some room, harden the material, then finish to size. If the latter, can I finish with HSS, or will it have to be carbide?
Thanks for the guidance.
ammcoman2
04-22-2010, 09:35 AM
I would recommend 1144. I think it machines better than O1 and one can get an excellent finish with either carbide or HSS tooling.
Just finished a spindle mounted ER25 collet chuck using 1144 and have decided that it doesn't need to be hardened as I am in HSM mode.
Geoff
Dr Stan
04-22-2010, 10:26 AM
If you harden it you will need to finish it by grinding or use an insert made for hard turning. Neither HSS nor standard carbide will work.
jb-mck
04-22-2010, 11:08 AM
Thanks, that answers my questions.
Spin Doctor
04-23-2010, 07:38 AM
http://img.photobucket.com/albums/v19/markandannie/Tips/P4230002.jpg
Came in at work the other day from one of our suppliers
KEJR
04-24-2010, 11:45 AM
Whats a special hard turning cutter? I've always used carbide or a grinder.
MuellerNick
04-24-2010, 11:54 AM
CBN, also available in the shape of carbide inserts. But they are a bit pricey.
Nick
Spin Doctor
04-24-2010, 12:02 PM
Nick
And don't even think about an interrupted cut OUCH :eek:
MuellerNick
04-24-2010, 12:19 PM
There's a geometry for interruped cuts available. Works up to 60 HRC. ISO-code "CBN 725 T".
But I have no experience.
Nick
.RC.
04-24-2010, 04:48 PM
How long a mandrel, what diameter, what sort of lathe do you have?
What sort of accuracy do you want..
