View Full Version : Shell Tonna 68 in Weiler headstock and gearbox?
djinh
04-28-2010, 05:40 AM
A few days ago a very pretty Weiler LZ VS2 found its way into my workshop :D
The manual I have talks about N36 DIN 51501 oil, but I can't seem to find any. I still have a big barrel of Shell Tonna 68 and its datasheet says it can be used in the headstock as well.
Is this true? Or should I get something else?
Alex
MuellerNick
04-28-2010, 07:33 AM
N36 DIN 51501 oil
Whatever that is, contact an oil manufacturer (Shell, $whatever) and let that translate to local standards. Before you ruin something.
Nick
form_change
04-29-2010, 08:54 AM
It depends on how much you use things, how many drums of oil you want sitting around and how much you trust oil sales reps versus machine tool sales reps.
I run Shell tonna 68 in my lathe gear boxes and don't have a problem, but then I'm a hobby machinist who is running a 50 year old lathe. If I were running a CNC machine for a business I would be using the manufacturer's recommended oil as I would be wary of taking a chance. I told the Shell rep what the original oil recommended was and he was able to identify equivalents and give me several options on what I could use. I chose the tonna 68 as I was already using it on the slides and he confirmed that it was a reasonable substitute.
Michael
lazlo
04-29-2010, 10:28 AM
Shell Tonna 68 is ISO 68 weight way oil (same stuff as Mobil Vactra #2). I seriously doubt that's what Weiler wants in the headstock.
That's a gorgeous toolroom lathe -- call up Weiler or get a copy of the manual and use the right oil. Most likely a hydraulic oil like the Mobil DTE series.
Or ship it over here and I'll find the right oil for you :D
http://www.metalwebnews.com/howto/chart/lube.html
