View Full Version : looking for scraping guidance. Repost (Pinging Forest Addy)
AlexK
04-29-2010, 06:33 PM
I have new Chinese 12x36 lathe. The cross slide binds at a certain position.
I took the crossslide apart.
The tapered gib was roughly machined and not flat. I have lapped it and it is perfectly flat now but dovetail recess where taper gib goes is not flat ether. You can feel gib rocking.
Looks like I need to learn scraping.
I have ordered Connelly's "Machine Tool Reconditioning" book and Michael Morgan "Basic Hand Scraping" DVD.
What tools do you recommend for hand scraping?
Any advise is appreciated,
Alex
AlexK
04-29-2010, 06:35 PM
Almost forgot.. I have a surface grinder. Is there any way I can use it in the process of "truing" the cross slide?
NzOldun
04-29-2010, 09:18 PM
Alex
Get an old (Scrap) parallel faced, parallel side file. Grind off the remaining teeth towards the bottom end, sides and edges. Grind across the end to a slight curvature and also so that the two edges on the end of the faces are at about 100-105 degrees to the faces, producing a slight 'V' ridge in the middle of the end, right across the end. Harden the end to white hard! Hone the faces and ends so that you have a razor sharp edge on the two bottom edges of the file. Happy scraping!
You will need to periodically re-hone the edges, as they become dull. If you can see light reflected off the two cutting edges - they're dull!
Cheap and easy start point. Better than carbide because you can get a razor edge.
