View Full Version : Aluminum flat bar suppliers..??
krems
05-01-2010, 07:42 PM
Does anyone know a supplier that carries 1" x 1.5" 2024 aluminum flat bar. I tried online metals, speedymetals, metal depot, metal express and didn't have any luck. I need to find 96 feet. I can find 6061 but not 2024...Any ideas? Any help would be appreciated.
Thanks...............Krems
Liger Zero
05-01-2010, 07:44 PM
MSC? Fastenal? Klein Metal Services?
Frank Ford
05-01-2010, 08:14 PM
McMaster-Carr has it:
http://www.mcmaster.com/#aluminum-alloy-2024/=6wmgb5
SGW
05-01-2010, 08:17 PM
McMaster-Carr www.mcmaster.com has it, page 3612, but it's pricey.
Edit: Frank, you beat me to it! :D
Ries
05-01-2010, 08:23 PM
Alaskan might have it.
They will UPS if you are not in Washington or Oregon- but they have to cut 12 footers in half.
http://www.alaskancopper.com/
or Samuel-
http://www.samuel.com/
these guys stock a lot of oddball aluminum alloys-
http://www.aerospacemetals.com/aluminum.html
Racebrewer
05-01-2010, 09:03 PM
Just in passing....... I found that Speedy has more than they list on their Internet catalog. Have you tried calliing?
If so, i'll just slide out now.
John:rolleyes:
Wrustle
05-01-2010, 09:35 PM
Try these as well, they are two of my biggest suppliers for aluminum.
http://www.emjmetals.com/index.htm
http://www.admiralmetals.com/Metalweb/index.jsp
Best Regards,
Russ
Boucher
05-01-2010, 09:42 PM
Not knowing where you are located kind of eliminates local suppliers. When you can drive over and pick something out of the cutoff bin it is often cheaper. Letting people know aproximately where you are will ultimately get you more help.
Liger Zero
05-01-2010, 10:46 PM
Yeah we're not going to track you down and take your stuff. :D
On a forum like this you need at least a state/country tag... heck I could be sitting two houses down from you and have exactly what you need but you'll never know without a location tag. :)
reggie_obe
05-01-2010, 11:11 PM
New England Brass? Enco?
gr8life
05-01-2010, 11:38 PM
Again a guy who does not want to say where he is! Why? I am quite sure I can find it local but if he is on the Moon or Mars the space program is ending soon.
Really silly. ThyssenKrupp aka Copper & brass.
thanks
ed
fishfrnzy
05-02-2010, 01:55 AM
EMJ metals, Ryerson, and Fry Steel ( LA area) should all have it. No affiliation with the above. It usually comes cold finished instead of extruded and will run 3-4 X the price of 6061.
krems
05-02-2010, 09:30 AM
Thanks for the leads....I'll call tomorrow to see if I can track some down.
I havn't called any of the places as I only did an internet search of the inventory listed.
BTW....I'm located in Bozeman, Montana USA
Krems
Steve Seebold
05-02-2010, 11:12 AM
Try Fry Steel in Santa Fe Springs CA. They have the best prices too.
lugnut
05-02-2010, 11:59 AM
http://www.aircraftspruce.com/catalog/mepages/alumbar.php
Mel
krutch
05-02-2010, 01:36 PM
I've gotten material through metal express that they didn't list. Call and they can get items they don't normally carry.
Krutch
