scmw
05-29-2010, 12:04 AM
Hi,
I'm fairly new to the forum and learning a ton of valuable information. I recently purchased some Bridgeport Series II NC mills that have been converted to Mach 3. I also have an A2Z modified Sherline 2000 with IMService's servo system and DeskCNC.
This past week I encountered some problems running a program on my Sherline due to stress on the electric grid. The 90 degree temps in Illinois caused a lot of air conditioners to start up and continuously run thus causing fluctuation within the grid.
I experienced several hiccups where the servos would simply stop running. Fortunately I didn't lose my registration and was able to home the spindle each time. The temporary fix was to slow down the program and get the part made, albeit a bit later than I wanted to but it did get done.
This has me thinking of how to avoid this in the future. I'm going to use an APC or other brand of UPS (Uninterruptible Power Supply) on the smaller mill. I'm wondering whether there might be a suggested size of UPS to use on the Bridgeports. They currently have steppers although I intend to upgrade them to servos sometime in the fall.
Is anyone using a UPS to protect their controllers and ancilliary equipment? If so, what should I look for with larger mills?
Thanks,
Terry
Thanks,
Terry
