View Full Version : what meterial do you suggest?
spkrman15
06-01-2010, 12:11 PM
I got asked to fix this part
http://i168.photobucket.com/albums/u172/Spkrman15/Picture006.jpg
It goes in this one. (they are side by side)
http://i168.photobucket.com/albums/u172/Spkrman15/Picture001.jpg
It is for a four wheeler. Part of the drivetrain. I beleive it is heat treated. I was thinking of making a sleeve out of stainless and welding it in. Any thoughts?
Rob :)
J. R. Williams
06-01-2010, 12:45 PM
Try 4130 or 4140. Stainless is too soft.
JRW
reggie_obe
06-01-2010, 01:59 PM
Part of a dog clutch assembly? The overzelous driver has managed to break 3 of the four dog before realizing something is wrong. I'd refer to the steel usage charts from mills like Carpenter and other. You want a combination of wear resistance and hardness, O-2 maybe?
Oldbrock
06-01-2010, 02:46 PM
I'd use 4340. peter
BillDaCatt
06-01-2010, 02:50 PM
This may be a dumb question and I approve of making parts to save money; but is there a reason that the customer didn't just buy a new one? My gut tells me that this part would be cheaper to buy than it would be to make.
Your Old Dog
06-01-2010, 03:23 PM
For all the longer it's going to last being that the guy broke 3 of the 4 dogs I'd make it out of paper mache' or aluminum. Was he a farmer by chance? I'm told they break, continue to break and then trash equipment before getting something fixed while its easy to fix :D
smalltime
06-01-2010, 05:04 PM
Ya' Beat me to it Dog.
"Ride it hard, Put it away wet."
rkepler
06-01-2010, 06:05 PM
I can't imagine that it could be made in a home shop cheaper than you could buy it, but if you're sure that you want to make it I'd use something like 4140 or maybe 8260. Both are good gear steels, and that's pretty much the application here. If you can you might consider heat treating to a maximum of toughness, stay away from maximum hardness.
spkrman15
06-01-2010, 10:15 PM
This is from one of those CHEAP imported 4 wheelers. They said it just broke...un hun! My buddy told me they got stuck with it the other day. You know, the rocking it back and forth to get out of a mud hole.
They have been trying for a couple of weeks to get a part but no one seems to have one. I would be helping a friend of a friend, making some cash (or breaking even) and learn something at the same time.
I am not very versed when it comes to metalurgy.
Thanks for the input.
P.S. All four teeth are broken
KIMFAB
06-04-2010, 11:35 PM
Hate to be a wet blanket here but you might also want to consider your liability if your fix breaks again and causes damage or worse yet injury.
