View Full Version : Material storage and organization
Boucher
06-21-2010, 10:40 PM
Been doing some clean up and organization and moving some things outside. I have a couple of steel pallets that I made years ago to load/unload 300-500gal water tanks onto a trailer. I also had several short pieces of well casing in various sizes. Combining the two makes for vertical storage in a manner that gives access without having to move a bunch of stuff to get to it. With the fork lift the whole thing can be moved if need be. I did wind up tacking the casing pieces together and lining them with short shots of 4Ē PVC
http://i109.photobucket.com/albums/n50/boucherbyron/IMG_0104.jpg
The larger piece of pipe on the right is setting on a light weight pre cast air conditioner pad. It is not moveable that way but the grass and weeds canít grow thru it.
Some material is just laid horizontally on old plastic valve boxes also left over from my water well drilling days. Better than being on the ground with grass growing up thru it.
http://i109.photobucket.com/albums/n50/boucherbyron/IMG_0105.jpg
KIMFAB
06-22-2010, 01:16 AM
I got some old telephone company frames that I made into a rack for the small stuff.
http://www.kimfab.com/pictures/shops/metalracka150.jpg
Made a rack for the 20 footers
http://www.kimfab.com/pictures/shops/metalracka151.jpg
Just to the right is the cutting table. I'll get a pic of that in the morn.
