View Full Version : gear cutter range
strokersix
06-22-2010, 06:46 AM
In another thread it is stated that standard gear milling cutter geometry is accurate for the lowest tooth count of the range.
Question is: If you wish to cut a gear one tooth less than the specified range of the cutter should you step down a cutter or would you be better off outside the specified cutter range?
06-22-2010, 08:28 AM
the form is more critical for lower tooth count.
I'd step down unless you gotta have the gear NOW, and you don't have the next lower cutter.
strokersix
06-22-2010, 08:53 AM
That makes sense, thanks.
New gearing applications I'll remember to choose tooth counts that are at the bottom of the cutter range if possible.
