View Full Version : Computer Thingy... Only $1... now what's it good for?
Liger Zero
06-26-2010, 07:42 PM
Found this at a garage-sale with a bunch of other stuff... Not sure exactly what it does... It seems to allow me to set up a remote station for my computer in another room/location via a network cable.
I'm thinking if that is what it does... I may have a use for it.
http://img.photobucket.com/albums/v469/Lizoid/PHOT0002.jpg
http://img.photobucket.com/albums/v469/Lizoid/PHOT0001.jpg
alanganes
06-26-2010, 07:50 PM
I'm thinking you are correct. "KVM" typically means "Keyboard, Video, Mouse"
I've seen lots of KVM switchers for sharing the keyboard, monitor and mouse among several computers. Have not seen one of those, but I would not have passed it up for a buck either.
Liger Zero
06-26-2010, 07:57 PM
If it works the "important" computer is going to live in a locked secure room and I will operate it with this. :)
JoeBean
06-26-2010, 08:12 PM
http://ca.ebid.net/for-sale/raritan-cat5-reach-remote-kvm-module-receiver-urkvm-15568709.htm
Remote (network) KVM receiver. You also need the transmitter (UKVM)
MotorradMike
06-26-2010, 08:15 PM
Whatever you do, keep the cover. If it really is made from 'Raritan', it's worth a lot. Not quite 'Unobtanium' but has many similar properties.
lazlo
06-26-2010, 08:21 PM
It's an analog (VGA and PS/2) KVM switch. It's worth about a buck :)
oldtiffie
06-26-2010, 08:42 PM
KVM = keyboard, video mouse - as said.
http://en.wikipedia.org/wiki/KVM_switch
I have one my two computers - both of which are on my desk. The K, V and M of each computer is connected to the KVM switch.
I just press Scroll Lock twice in quick secession and it switches my single K, V and M's between the computers.
It means that I can have both computers running and switch between and have the use of either computer - but I only need one Keyboard, Video (monitor/screen) and one Mouse which saves me either changing each time I want to use the other computer or having the desk cluttered with two K's, two V's and two M's.
Each computer is connected to the ADSL modem.
It saves me having to net-work my computers.
Each computer has an external 200+GB external USB SATA drive - which are real big "thumb" drives and that I can plug into each computer - "live".
All of my computer HDD's are in removable trays and are inter-changeable.
Both computers have identical/same main boards - one running XP Pro and the other W7 platinum - so if one fails totally I can just use the removable drives.
I totally back-up (image) my boot HDD on each computer every month and back up all data every week - some daily.
Each computer has its own separate Uninterpretable Power Supply (UPS).
That KVM device is a key part of it all. I have a spare of that as well.
Liger Zero
06-26-2010, 08:56 PM
So what I have... is useless without the "transmitter?
Magnum164
06-26-2010, 09:12 PM
As well I think you need computers with PS/2 connections. Most now are USB and I had trouble with my old KVM using a PS/2 to USB adapter. I am still looking for a cheap KVM that works with DVI/HDMI monitors...
Liger Zero
06-26-2010, 09:18 PM
Alrighty then! I'll take a screw-driver to them and see if there is anything interesting inside. Might as well get a bucks worth of entertainment out of it. :D
