View Full Version : metric seal for coolant pump
dneufell
06-29-2010, 11:28 PM
Hi Guys! My coolant pump was leaking thru the weep hole the other day.
I bought a new one but would like to fix my other spare pumps. there are 2 bearings (6200z) Found them on Ebay for a few dollars each. I can not find
the seal (google search) It is 25 mm od x 10 mm id x 7 mm long (KCM printed on seal) ...... bummed out.....any leads? Thank you very much...Dean
lakeside53
06-29-2010, 11:55 PM
Go to any Napa store. They can cross reference it to some very common part numbers - they will likely have several alternatives - you'll have to decide the seal constuction/lip type etc.
Any bearing house will likely have it in stock also.
If you are searching online, the size is 10x25x7 - order is important. A simple search on this returns many possibililities.
dneufell
06-30-2010, 06:38 PM
Thanks Lakeside53.....I try the NAPA guy tomorrow....hopefuly they will have
a cross ref.........Dean
