For internal NPT threads, I've found lots of references that talk about running a tap in for twelve threads to get the proper fit. What's the math behind this?
How deep to tap NPT internal threads
At work we use npt gages so there is some consistency from one person to another. At home I usually just buy a pipe plug the same size that I'm tapping and use it for a gage to determine how deep I need to tap the hole. Just use the "looks about right method" with the plug. It's cheap, simple, and works. Just the way I like it.Jonathan P.
My old instructor's command is the "3 to 3-1/2 turns" thing. He told me to shoot for 3-1/2 turns, meaning: Tap the hole conservatively. Using a pipe plug, screw it in to finger tight, then count how many full turns it takes to pop out of engagement and be loose in your hand. When you have 3-1/2 turns, it's done.
I don't have any of the official gauges at home now, so this method is all I have. Thankfully, it seems to work.
A little more looking yielded this:
"To achieve the basic thread depth, a machinist typically drives the tap into the workpiece 12 turns."
"The application, with proper gaging, will determine the appropriate depth for the proper mating of the parts."
From: http://www.ctemag.com/dynamic.articles.php?id=59Any products mentioned in my posts have been endorsed by their manufacturer.
Was taught to leave 5-7 threads out . Found out by gaging many many pipe taped threads that 6 thread will be just about perfect. so hardley even use gages any more.Every Mans Work Is A Portrait of Him Self
I've ran into this problem several times in the past. I also had a thread going a while back. I guess I'm not the only person that has problems with threadding pipe, or pipe threads. I have finally dawn the conclusion that plumbing is the art of cobbing, so just thread to fit.
JL.............................
It's in the thread spec:
See, 5 turns there.
Since it's a tapered thread, it matters how many. Note the "hand tight" spec as well.
BW---------------------------------------------------
5 still sticking out.
