jihe
07-04-2010, 10:04 AM
I have just finished the spindle encoder for my newly cnc converted mini lathe. It seems to work fine and I can thread with G33 without problems.
G76 is giving me a headache though.
This is the example from the manual thats supposed to thread a 1/2 20 tpi (first the original, then my metrified):
G76 X-0.210 Z-1.25 K.040 D0.003 F0.050 A60
G76 X-5.334 Z-7 K1.016 D0.0762 F1.27 A60
What happens on my lathe though is that it seems to turn an ID thread. It retracts the tool in the direction of the _workpiece_ when Z-1.25 is reached. If I remove the minus from X, it adds X to the feed for the first pass :eek:
I have tried many other X values but I don't really see a pattern in what it does, except for occasionaly crashing my tool really deep in the material :(
I think the main problem is that I don't really grasp what the X value is supposed to do. It isn't even mentioned in the manual.
In this thread (http://tech.dir.groups.yahoo.com/group/turbocnc/messages/10089?threaded=1&m=e&var=1&tidx=1) Dave K writes:
X is the root or minor radius (or diameter) of the thread
That sounds reasonable, but doesn't explain my weird results.
The lathe is setup so that X+ is away from the operator and my tool post is front mounted. I THINK the example from the manual would work for an external thread if I had a rear mounted tool post. So if TurboCNC had a setting where I could tell it where my tool is located, I guess it would work. But I can't find such a setting.
When I read my post I realize it's not the clearest. But I would really appreciate any pointers to information. Maybe someone has examples of G76 lines actually used with TurboCNC?
