View Full Version : How do I get that dam plasticizer smell out?
beanbag
07-08-2010, 10:28 PM
Bought some safety goggles from HF. It's the kind with a plastic lens and a clear, flexible rubber/plastic border around it that seals around your face. It has that plastic / vinyl smell, which is bothersome. I tried leaving it out in the open a few days and also washing with hot soapy water, but the smell is still there. How can I get rid of it? (The smell, not the goggles)
Liger Zero
07-08-2010, 10:49 PM
Bake them at 120-150 in an oven to drive the last bit of plasticizer and finish the cure.
beanbag
07-08-2010, 10:51 PM
Is that F or C?
And isn't that going to mess up my oven? (it's gas)
Liger Zero
07-08-2010, 11:02 PM
I could be cruel but I won't... It's F. ;) C would destroy your goggles. :p
Turn the oven on, let it heat then turn the heat off, stick your goggles in. Then let the oven air out.
I forget not everyone has an old converted stove-oven in their workshop for this kind of thing, sorry. :D
J. R. Williams
07-08-2010, 11:17 PM
Take them back to the place of purchase and demand a refund. Sears had a similar problem with plastic screwdriver handles many years ago. There was no formal recall but they did replace them if the customer complained
JRW
macona
07-08-2010, 11:21 PM
Just throw them on the dash of your car on a hot day, that ought to do it!
I dont know, I kind of like the smell of fresh goggles.
KIMFAB
07-10-2010, 10:04 AM
I just lay them out in the sun for a couple of days.
But then it was 118 in the shade by the pool yesterday and 88 when I got up this morning.
I just realized that I'm now a senior member. Today I'm feeling a little more senior than usual.
Spent yesterday crawling around under my rental fixing plumbing, now I get to pay for it. Wish I wasn't so cheap.
Liger Zero
07-10-2010, 10:19 AM
The key to getting the stench out (I don't mind it) is low heat. Doesn't matter how you do it, just keep in mind too much heat can cause warping and melting.
beanbag
07-17-2010, 04:10 AM
I couldn't find a "spare oven" to do it in that wasn't already coated with horrible chemicals. I tried leaving it out in the sun for a few hours these last few days, and the smell is "less bad". Somebody else told me that you need UV, some heat, and ozone to get the smell out, but the smell is what keeps the material flexible, and once that is gone, it will harden.
