View Full Version : Check your new 5C spin index or other tool
mototed
07-12-2010, 07:07 PM
Before using your new Phase II 5C spin index make sure you go through the entire tool and tighten everything up with a wrench. Good looking tool, it appeared that it was ready to go out of the box, but all fasteners where a little less than "wrench tight" Couldn't move anything by hand, found out the hard way. My part slipped, My fault, all of it was tightened up but not enough for real working conditions. Put a wrench on those new tools before use.
John Stevenson
07-12-2010, 07:13 PM
What fasteners ? It only has a drawbar tube for the 5C collet ?
TGTool
07-12-2010, 07:17 PM
I think the OP has a point. From my experience a nut loose in the shop can cause endless headaches for everyone else.
Carld
07-12-2010, 08:01 PM
The only fasteners on my spin idex is three set screws on the collar and the drawbar for the collet.
What fasteners came loose and what happened?
mototed
07-12-2010, 08:52 PM
Mine has a collar nut (spanner nut) that holds the index plate tight, it threads against the plate to hold it, Slipped off by a degree due to being almost tight enough. Didn't notice until, after I had already plunged a drill bit in.
Just saying to check your fixtures before using. Parts will come loose, don't assume that those screws are tight.
Ted
tlfamm
07-12-2010, 09:31 PM
Alas, you are 25-years too late:
not having performed the check you suggest, my brandy-new Indian-made toothed grinding-wheel dresser came apart at speed (the axle was not screwed tightly into the tool), sending a tiny sliver of shrapnel into the white of my eye. Off to the emergency room, and on Christmas day, of all days.
Then as now, I'm no aficionado of Indian-made goods: but at the time of purchase, my thought was, "Well, it's only a wheel-dresser, how can they screw that up?"
oldtiffie
07-12-2010, 09:39 PM
Here is a "Spindexer":
http://i200.photobucket.com/albums/aa294/oldtiffie/ER-32_C5/ER32-C5-8.jpg
I only use the indexing pin to locate the spindle - and then I use the knurled thumb-screw (on the top of the "barrel") to clamp the spindle. More often than not I will withdraw the locating pin anyway - "just in case".
I am not at all sure that the fairly small indexing pin and its housing in the main body casting and the indexing plate are meant to take or resist any machining loads.
Its the same with my rotary tables. Unless I am circular milling, I clamp my table whenever I am cutting and do not rely on the worm and worm-wheel to keep it in position. I prefer to have the least load on the worm and wheel as possible as they are intended to be a location device and not a holding device (unless circular milling).
"Load hammering" on the indexer on a worm and wheel in a rotary table or on the location pin on a Spindexer will certainly not improve them.
The clamps on the "Spindexer" and the rotary table were put there for a purpose and a good reason - use them.
Ken_Shea
07-12-2010, 10:02 PM
Another thing that is a good idea to do as a general rule, replace all the 1/4x20 set screws in any of these units as well as those in the cheap AXA/BXA tool holders.
They all seem to be just junk and improperly sized.
Black_Moons
07-12-2010, 10:20 PM
I still need to get/make a pin wrench for my 5C spindex index plate collar..
07-12-2010, 10:29 PM
Tiff,did you do the ER mod to that indexer or is that a bought item?
oldtiffie
07-12-2010, 10:56 PM
You have a very sharp eye weird.
I bought it from ArcEurotrade in the UK (it is a John Stevenson design). It can use either C5 or ER-32 collets.
Arc Eurotrade has a C5>ER-32 retro-fit adaptor for standard C5 spindles. I bought that as well for my T&C and Universal grinders which have C5 spindles and very good (metric) C5 collets, but I wanted to expand my capability to hold all jobs from 2>20mm (~0.080>0.800") as the ER collets have a vastly better range of 1mm (~0.040") which far exceeds that of the C5 collets.
The "native" C5 collets are better than the ER-32 ones (but as it happens, by very little) as the C5>ER-32 adaptor has the possibility/probability of injecting its own errors into the total run-out picture.
ER-32 collets are my preferred collets but I do use the C5 collets for better (metric) work on the T&C and universal grinders.
Edit.
Here are some pics of the ER-32 and C5 collets and the adaptor in my Spindexer:
http://i200.photobucket.com/albums/aa294/oldtiffie/ER-32_C5/ER32-C5-11.jpg
http://i200.photobucket.com/albums/aa294/oldtiffie/ER-32_C5/ER32-C5-18.jpg
http://i200.photobucket.com/albums/aa294/oldtiffie/ER-32_C5/ER32-C5-19.jpg
http://i200.photobucket.com/albums/aa294/oldtiffie/ER-32_C5/ER32-C5-20.jpg
End edit
KIMFAB
07-13-2010, 12:23 AM
I'll second this after having one break inside. Took a while to get it out.
I think they make those setscrews out of metal covered self shattering plastic.
dneufell
07-13-2010, 01:20 AM
here is our cracked spacer on the spindex (with faster/stronger/most excellent new spacer next to it) :) .....Dean
http://i167.photobucket.com/albums/u141/dneufell/MVC-001F-1.jpg
motomoron
07-13-2010, 02:02 AM
The indexing pin on a spin index is loaded only in shear and it's strength should be multiples of the torque that can be transmitted by a properly tightened 5C collet.
