View Full Version : taurus pt140
wooleybooger
07-14-2010, 09:20 PM
a friend has a taurus pt140 that he lost the front sight on. he asked me for help but i dont know what it had originally. it appears to have had a staked in sight like the old 1911s as it has a different colored piece of metal left in a small hole in the slide. i dont know if that piece is pressed in or threaded. i can make a sight blade with tenon but it would have to be silver soldered in. i cant find aftermarket replacements for this pistol but i have found dovetail sights for newer models. taurus says send it in.
v860rich
07-14-2010, 10:12 PM
From what I know about Taurus I would send it in. They fix their fire arms free for life, and usually send the repaired weapon back with an extra clip.
THANX RICH
People say I'm getting crankier as I get older. That's not it. I just find I enjoy annoying people a lot more now. Especially younger people!!!
chriskat
07-16-2010, 05:42 PM
The exploded view from the manual, two jpgs below sorry they aren't very good quality, show a front sight screw and a rear sight screw. Might the original have been attached with a screw which is sheared/wrung off?
http://home.comcast.net/~chriskat/pistol_manual_03%20%5B640x480%5D.jpg
http://home.comcast.net/~chriskat/pistol_manual_04%20%5B640x480%5D.jpg
chriskat
07-16-2010, 05:46 PM
By the way the entire manual is at the following link:
Taurus PT140 Manual (http://www.taurususa.com/pdf/pistol_manual.pdf)
Jeff
wooleybooger
07-16-2010, 09:50 PM
thanks,jeff. it seems you are right. after enlarging the pdf pic it looks like the sight has a dovetail at the rear secured by a screw at the front.my buddy said it always showed "daylight" between sight and slide before it disappeared. the slide does have a plunge-cut slot milled into the top but i never thought about a rear dovetail. if it showed "daylight" the sight or slot was over/under sized or the sight was slapped in and screwed down without checking fit. i have 2 taurus 1911s with (formerly) poor fitting front sights so slapped and screwed would be my guess. thanks,mike
