View Full Version : have welding question on gas tank
airsmith282
07-17-2010, 11:43 AM
i have gas tank on an old snow blower i have to reattach the pecock tube and i have a crack in the sournding area , can i use flux welder or is it best to braze it together its pretty thin stuff but i want this tank functional again ,
EddyCurr
07-17-2010, 01:38 PM
Do you have some thoughts about purging the tank before applying flame
for a repair?
airsmith282
07-17-2010, 02:51 PM
already been done
danlb
07-17-2010, 05:42 PM
Unless you are a crackerjack welder, I'd go with brazing. It's more forgiving and not as likely to burn through.
Dan
davidh
07-17-2010, 05:52 PM
i've had good luck using a old soldering iron (copper head monster) and and solder. then to insure it would be good i used por-15 tank coating. this was on a farmall c
airsmith282
07-18-2010, 06:10 AM
I already tried to solder it and that didnt work out at all and yes i know how to solder got 30 + years in at soldering and it does not want to hold i get to the last 3/8 of an inch and it wont seal up
can brazing be done with just the use a map fule tourch only and the brazing rod,as i ran out of O2 for my tiny little kit
Duffy
07-18-2010, 09:17 AM
I think that you will have real trouble brazing an area where you have previously tried soft solder. Apparently the intermetallic compound of tin and iron, (from the tin/lead solder,) screws up the brazing process. At least it does for silver brazing. ALL the "steam boys" say that it is hopeless to try and braze over a former solder joint.
Since this is not a pressure joint, how about using some 30/70 body solder and "wipe" the joint. there will then be enough metal for strength.
arcs_n_sparks
07-18-2010, 10:37 AM
Tank is open as you try to solder/braze it?
Willy
07-18-2010, 03:14 PM
I too would try again with solder rather than attempt to brazing it after the first failed attempt at soldering as I too find it very difficult to braze after soldering. Unless one has the luxury of getting in there with an angle grinder and getting back to white virgin metal it won't work. I don't think you have that option.
I'm sure you are aware of this as you've done lots of soldering before but I just want to reemphasize the fact that in soldering cleanliness of the metals to be joined is paramount. It almost sounds like there might be a trace of contamination left on the metal.
And as as arcs_n_sparks suggested, make sure you don't have any air pressure build up in the tank as that too would cause the last bit of the joint to not seal.
Also as a last resort I have had good luck with repairs of this nature while in the field without tools by using JB Weld. I know some will avoid this type of repair but done properly it can sometimes save the day.
Good luck and let us know how you make out.
ironmonger
07-18-2010, 04:49 PM
If you were to weld this I think that you would be better off using tig or gas welding. If you are out of O2, you might try silfos brazing alloy with a silver solder brazing flux.
You might be able to clean up most of the soft solder, but without the gas torch it is going to be very difficult to control the warpage while trying to heat the tank hot enough to even silfos the joint using a mapp gas torch... it's only a few hundred degrees lower melting point than BAg alloy silver solder.
Regardless of the alloy you use, the crack should have a patch to increase the surface area of the joint and reinforce the crack. none of the brazing alloys are very flexible, and flexing might cause even a perfect joint to fail if you are successful in butt brazing it.
I know that the conventional wisdom is that you can't braze over soft solder joints, but some years ago we did silfos some 3/4" copper tube joints in that manner, while they were not pretty they did hold a pressure test.
paul
airsmith282
07-19-2010, 06:24 AM
what about JB weld or liquied metal, would these work or should i really try the soldering idea again,
i made sure the gas cap was not on the tank so no pressure build up there at all.
ironmonger
07-20-2010, 03:52 PM
While the JB weld might not be affected by the gasoline, the fact that the tank cracked seems to indicate a high stress point. The amount of surface area to bond to the JB weld would be tiny...
If you really can't weld or braze it you might pop rivet a patch on the bottom and have the inside of the tank coated with gas tank sealer....but before you did anything that flaky though, I would rather have you take the tank somewhere to have it welded
paul
Jim B
07-21-2010, 02:50 PM
vis-a-vis soldering, there is a product used in stained glass. It is thin copper foil with a sticky tape on one side. I have a bunch because my wife does that stuff.
I would bridge the gap with this and then overcoat it with solder. I have had good results doing this on similar problems.
Jim B
duckman
07-24-2010, 10:57 AM
What kind of flux are you using if its not an acid type not gonna work, get a small wire brush, gently heat the tank where your gonna solder, scrub with brush, add flux heat again add solder, should be good to go, if you have small pin holes, flux and solder on a small piece of brass shim stock. Not being a smart ass but thats the way I've always done it, never had one leak again at the same spot.
BillDaCatt
07-24-2010, 03:21 PM
MAPP gas is probably the perfect fuel for soldering a project like this, however you will need a torch head that is made for use with just MAPP gas. Without oxygen your Oxy/MAPP torch will not have the proper air/fuel mixture and will give you poor results. If you don't already have one, a MAPP torch head is about $35 at most any store that sells plumbing supplies and usually comes with a tank of fuel.
I also second the suggestion for using acid flux.
