jb-mck
08-04-2010, 07:07 AM
Greetings:
I have a SW 1000 12 ga. shotgun that I was given back in 1981 or so. I love this gun! The problem I have that miss fires frequently. If I clean it really well, I will get about 15-25 rounds through with no problems. After that, the second shell does not want to fire. There is a light strike on the primer of the shell.
The problem seems to be less severe with different shells. The heavier the load, the better it works.
Years ago, I was a young, I tried dissembling the mag tube by using a screw driver stuck through the side slots on the tube. I ended up warping the tube making the gas cylinder hard to slide. I honed it the best I could but I never got it quite right. I think this is related to my problem.
Also, this gun has had many, many, many shells through it. It has much wear. I found a site that sells a new bolt group (firing pin, bolt, ejector) but nobody I have found has a mag tube. My plan was just to replace all parts mentioned.
Questions:
Does my plan to fix sound reasonable?
If mag tube can't be found, can I fabricate, if so, what material?
Anyone know where I can find the parts?
I realize it will be difficult to diagnose the problem based on this info. I would appreciate any guidance I can get.
JM
Questions:
JM
