View Full Version : Drill bits/Reamers/Taps New or Used
Magnum164
08-13-2010, 09:09 PM
I need to start purchasing some drill bits/reamers and taps. Already projects are slowing as I have to wait for a certain drill bit.
I have come across a few deals on used items and just curious if others think it is worth buying used. I definitely want to make sure if I buy something used they are true and in tolerance. I have never sharpened bits but understand it's fairly easy to do.
Just seems cheaper to buy a few lots of used so I will at least have a larger variety faster.
Arcane
08-13-2010, 09:18 PM
At least with used bits you can sharpen them regardless of their quality and be reasonably sure they will drill a hole the size they say within the tolerance limits you would expect for drill bits.
If I was buying a reamer, it would be to make a very precisely dimensioned hole, and I wouldn't expect a used reamer to be able to do that for me. Personally, I'd stick with buying new when it comes to reamers, and buying quality ones at that.
gregl
08-13-2010, 09:21 PM
I learned my lesson the hard way. I now buy only new, good quality. Nothing is more worthless than a dull tap, and you can't really tell by looking. And I have been to any number of garage sales or auctions where reamers are just tossed into a box along with other tools, thus banging up the edges and ruining what is supposed to be a precision cutting tool. I would not trust any reamer that isn't new. Drill bits are easier to sharpen but unless you need a bunch of them or some unusually large size, I don't think it's worth it to buy used. The name brand ones just seem to cut better and hold an edge longer.
If you buy what you need as the need arises, you will soon have a good collection of the sizes you use and you won't have spent money on a set that might include sizes you'd never use.
There are many places in the shop to save money but in my opinion this is not one of them.
Rustybolt
08-13-2010, 09:22 PM
get back to us after the first hundred or so, off hand, or course.
Your Old Dog
08-13-2010, 09:30 PM
I bought a 135 piece set of foreign import about 20 years ago. I use them daily and have only broken the #21 bit.
I bought a set of SASE tap and dies from Harbor Freight and now that I use a guide to start the taps plumb, I've had no problems. I bought a seperate set of under size bits and chucking reamers from Enco for when I need precise holes of 1/4, 5/16, 1/4, 3/8, 1/5 and plan to buy more for when really accurate sizes are needed.
I'm home shop and don't do any commercial work. If I did, I might feel otherwise but I think my bits and taps are a good deal for me.
Magnum164
08-13-2010, 09:32 PM
Thanks for all of the quick replies. I was leaning towards buying reamers and taps new, but wanted to get some input. So will probably just keep buying what I need as I need it.
Guess I'll look through Enco for a few of the sizes I need the most.
Magnum164
08-13-2010, 09:34 PM
For now I am home shop as well, at least for a while but will never really do any production. I am mainly doing one-offs and prototypes.
snowman
08-13-2010, 11:10 PM
I only talk about machining, so used works fine for me.
KiddZimaHater
08-14-2010, 01:58 AM
Drills are OK to buy used. They're easy to sharpen.
Taps and Reamers should be bought new.
Dull taps like to break in holes, and dull reamers make over-sized holes.
SGW
08-14-2010, 11:39 AM
I agree with the others -- don't bother with used taps and dies or reamers. Buy top-quality stuff, as you need it, and the incremental expense spread over time won't be too bad.
Personally, I wouldn't bother with most used drills, either. Buy a top-quality set and you won't have to worry (for a while, anyway).
lakeside53
08-14-2010, 12:25 PM
I have 300+ "used" reamers... and no issues - it all depends on where you buy them. Mine were from the estate of a machine shop. I have acquired a few dozen more large reamers from garage sales for close to free, but most were dull and worthless in their current condition.
I also have a reamer sharpener - just does the end that cuts, but haven't used it yet.
To fill in the gaps (there are always gaps!), I bought on Ebay a set of old Keystone adjustable reamers - in pristine condition or less than $00 delivered.
Drill bits - Try pricing a set (that's one of each drill..) of quality USA brands from #80 to 1 inch in just machine screw length... I did.. wow! So... I bought another machine shop liquidation inventory at auction. Everything from #80 to over 1 inch, in letter, number and fractional. Dozens of new drills (mainly cobalt) in most size compartments with machine screw, jobber and many "aircraft" lengths. Total drills? Maybe 1500+... I paid $450 - less then the price of the cabinets even when on sale.
hornluv
08-14-2010, 12:41 PM
With taps, may I suggest buying spiral point taps. They drive the chips forward so you don't have to turn back every quarter turn to break the chip. They also require a good bit less torque to cut, so they are less likely to break. They are excellent for tapping under power, but can be used by hand just as easily. For blind holes, you'll want to either drill a bit deeper so the chips have someplace to go or use a spiral flute tap (flutes have a helix angle like a drill), which draws the chips out of the hole.
Magnum164
08-14-2010, 12:45 PM
I will probably order a few batch's of used drills, reamers and taps definitely new based on feedback. I guess that is the same reason I buy new vehicles instead of used:)
lakeside53
08-14-2010, 12:52 PM
Yes.. That's what I buy and I really like both of them... On the spiral flute it's neat to watch the three spirals of swarf curling cleanly out of the hole :) Sharpening the Spiral point taps is a breeze.
Magnum164
08-14-2010, 12:57 PM
Estate sells is what I was thinking as I would assume the condition would be a lot better than just buying used from individuals. Would like to think a shop took better care of the tools.
becksmachine
08-14-2010, 08:05 PM
X2 on that! ;)
Magnum164
08-14-2010, 09:06 PM
X2 on that! ;)
Guess I am comparing sharping them to the only other thing I sharpen regularly every couple of weeks. And that is lawnmower blade. Pain having to lift the mower with a lift and craw up under it with a dremel tool...:D
RobbieKnobbie
08-14-2010, 10:11 PM
I've gotten litterally hundreds of taps, morstly new, some used from machine shop auctions (real auctions - not to be confused with ebay!). In this economby they're coming almost one a week around here to the point where I've accumulated more drills, taps and reamers than I'll ever be able to dull in my lifetime... Usually buying a few dozen taps for the price of one or two taps retail.
Last week I got (among other things) fourteen reamers between 17/32 and 1 1/8 for less than $25. Of those three or four looked to be brand spanking new, the rest were used but completely servicable. There were another couple that were shot, but I just threw them in the scrap bin.
Taps, especially gun taps, are very easy to resharpen, just allow a few to practice on and make sure you leave a reasonably positive rake on the cutting edge. Each tap can be sharpenedonce, maybe twice freehand once you get the hang of it.
