View Full Version : Excello Ex-Cell-O XLO model 602 manual
bkahler
08-18-2010, 08:57 AM
Not sure if this is the correct place to post this. If not I apologize.
Back in early March I acquired an older Excello 602 mill. I was able to locate a manual for it although it actually covered the later model 602 but it was still handy to have. One of the problems with the manual however was the poor quality of the reproduction.
Well recently I managed to buy a good condition manual on eBay for the earlier model 602 mills. Yesterday I took the time to scan the manual at 300 dpi in color. This made for a very good reproduction of the manual in PDF format.
For those of you with earlier 602 mills and would like a good copy of the manual you will find the pages located at the links below. Each scan includes two pages and they run about 1.5 meg each in size. There are 18 links for you to download.
If you print them out you will need to print them on 11 x 17 paper.
I hope this helps someone when working on or repairing their 602 mill.
Enjoy!
Brad
http://campkahler.com/files/xlo-52672/xlo-602-52672-front-back.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-index.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-2-3.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-4-5.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-6-7.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-8-9.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-10-11.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-12-13.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-14-15.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-16-17.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-18-19.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-20-21.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-22-23.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-24-25.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-26-27.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-28-29.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-30-31.pdf
http://campkahler.com/files/xlo-52672/xlo-602-52672-page-notes.pdf
MaxHeadRoom
08-18-2010, 09:30 AM
Links do not work, BTW, the last time I spoke to Excello Service on a gear box issue, they mentioned that they now recommend Transmission fluid in the G.B.
Max.
lazlo
08-18-2010, 09:35 AM
I have the full modern Excello 602 manual, if anyone wants it.
bkahler
08-18-2010, 09:42 AM
Max.
Sorry about that. Somewhere in the copy process from my computer to the message input page they got scrambled. Hopefully they work now.
Whoever had the mill before me used some sort of red fluid which based on your comment means it was probably transmission fluid.
Thanks!
Brad
