View Full Version : Help with DAREX D3
paul
08-21-2010, 11:41 AM
Thank you all for you input. I am planning to order some AO wheels for my DAREX D3. What grit should I order?
PeteM
08-21-2010, 01:22 PM
60 grit is what I use. If you'll be doing mostly small bits, you might want to go up around 80 grit or so. You want the wheel to do the work, so just gently rotate the bit into the wheel. Take more passes, rather than force things.
