View Full Version : Where to get pulley for metric shaft?
winchman
09-04-2010, 12:40 PM
I've got a GE air compressor motor that came with a broken die-cast zinc V-belt pulley on it. The motor shaft is OK, and I've cleaned it up and removed a few burrs. The diameter is 0.672-0.674", which is pretty close to 17mm (0.670"). The OD of the pulley is about 5 inches, and it's got a single 1/2" V belt groove.
Where can I find a similar pulley with a metric bore? McMaster-Carr and MSC don't have any listed. The motor shaft has a flat for a set screw, so I don't need a keyway.
Should I just give up, buy one with a 5/8" bore, and bore it out?
vpt
09-04-2010, 01:19 PM
Sounds easiest and best to me.
Willy
I would just bore out a 5/8" pulley. Don't think you will find one with a 17mm bore.
You may have a proprietary motor as IEC or metric frame motors do not come with 17mm shaft sizes that I'm aware of at least.
Willy
09-04-2010, 01:22 PM
Forget to ask, is there an id plate on the motor signifying as to what it's pedigree is?
RWO
09-04-2010, 02:04 PM
Reid Supply can supply a pulley bored to suit your needs. Fill out the quotation form and get a price.
http://www.reidsupply.com/
RWO
winchman
09-04-2010, 02:22 PM
The GE motor model number is 5KCR49SN2018X. I couldn't find any info about it. The shaft is about 3/4" long.
Boucher
09-04-2010, 05:35 PM
Red Jacket used to machine the end of the motor shaft running the motor. You could turn the shaft to 5/8 using that technique.
