View Full Version : Old Craftsman lathe, sell or keep?
woodnerd
09-24-2010, 11:12 AM
I inherited this old Craftsman lathe when my dad died a few years ago. I've just recently become interested in machining and want to work with CNC.
I'm wondering if this lathe is worth keeping. I've had some people tell me it's not a very good one and I should sell it and get something like a Grizzly G0602. Others say it's a pretty decent lathe and the Grizzly would actually be a downgrade.
What do you guys think? Are there any issues that would keep this lathe from being converted to CNC?
What would this lathe be worth? I've searched around and found prices from $400 up to $2500
http://www.thewoodnerd.com/images/homeMachinist/_DSC4144.jpg
http://www.thewoodnerd.com/images/homeMachinist/_DSC4145.jpg
http://www.thewoodnerd.com/images/homeMachinist/_DSC4146.jpg
Deja Vu
09-24-2010, 11:16 AM
Keep it!! Use it! (as long as you have room for it, or need the money.)
gzig5
09-24-2010, 11:27 AM
That's a good machine and looks exceptionally clean, though probably not the best candidate for CNC conversion. It would be an excellent machine to make the parts for a conversion though. If you want to do CNC you need to decide how big of parts you want to be able to do and design the machine around that envelope. No sense in buying four foot long ball screws if a one footer will do. Depending on what accessories you have and where you are, I could see that machine selling for between $1000-1800. This opinion is worth exactly what you've paid for it.
38_Cal
09-24-2010, 11:54 AM
Value will depend on what accessories you have with the machine and where you are located. It looks obscenely clean, and should give you quite a bit of service and enjoyment.
David
lakeside53
09-24-2010, 11:55 AM
Very nice condition lathe... I'd just use it.
Price depends on where you live (please edit your profile and show location...). Around here (Seattle area) you could get $1000-1500; more if a collector wanted it for it's excellent orginal condition.
gaston
09-24-2010, 12:02 PM
Keep it and use it. I've got its twin and it is a great shop lathe. It does all I ask of it just fine.
kendall
09-24-2010, 12:03 PM
Agree, it's a worthwhile machine to have. Would be very happy to have it in the shop
Think the biggest issue with Atlas lathes is that people tend to use them like they were bigger machines.
Tony Ennis
09-24-2010, 12:04 PM
A good machinist can do a lot on those lathes. That particular model is one of the later ones which were much improved. And it looks very very clean. I'd keep it, use it, and leave it unmodified.
Check the usual suspects for a new lathe with DRO.
Cobbler
09-24-2010, 12:10 PM
I'm not a CNC person but I have a few friends who are. The funny part is that those CNC friends are often found in my workshop using my manual machines because it is a PITA to do a quick job on a CNC where it is a snap on a manual machine.
Keep it (or give it to me :p ) and use it to build your CNC stuff. There is always a place in the workshop for a manual lathe that size.
john hobdeclipe
09-24-2010, 01:16 PM
You could probably sell it for $1200 - $1500, but you'd soon regret it when you start shopping for a replacement. Whatever you do you'll need a decent manual lathe, and you have one right there, so keep it and use it.
By the way, has it ever been used at all?
polepenhollow
09-24-2010, 01:41 PM
It is a very useable machine. It is a little light but very handy. Get a 4 way tool post or Aloris style tooling.
With an Atlas identical to yours is how we paid for our first house in 1975.
I would set it up at night and my wife would run it during the day while I was at work as a Tool & Diemaker.
She was 8 and 9 months pregnant at the time, and when I came home in the evening her huge tummy was covered in oil and chips.
K Lively
Peter.
09-24-2010, 02:28 PM
I'm going to go against the grain and say sell it. In that condition it will attract a premium and the money can go towards a more modern and more robust replacement, that will suffer the trials of your learning much better even though it probably won't be in nearly as nice a condition cosmetically.
whitis
09-24-2010, 03:35 PM
It is a rebranded atlas lathe.
Given that the condition looks very good, that might be worth keeping. It looks to be near the top end of atlas lathes rather than the bottom. It is a family heirloom and the price was right.
I suspect CNC conversion shouldn't be too difficult - it looks easier than a lot of lathes I have seen. While the quick change gearbox can interfere with access to the left side of the lead screw, you have access to the right side and a support that can easily be detached and replaced with a stepper mount. Attaching a mount to the cross slide shouldn't be too hard. Use double end shaft motors so you can mount a handwheel on the back side. Put a negator spring on the cross slide to take up the backlash if you are, for example, taking finishing cuts on a taper where the cutting forces aren't enough to take out the backlash. Look for a way to attach an encoder to the spindle without getting in the way. An extension to the left side of the spindle with a 25/32" bore and a 1" OD could be used with one of the US Digital large bore encoder wheels. If that isn't practical, there are probably places you can mesh an encoder wheel with a gear with one of the existing gears; not quite as good but should do ok. If you will be cutting shoulders on the left side or tapers that get thinner approaching the headstock, then a negator spring pulling the carriage towards the tailstock and very light cuts are in order.
Downsides: poor rigidity for its size, doesn't have 1-3/8" spindle bore, threaded spindle nose (so be careful if stopping suddenly or running in reverse or the chuck may come off) instead of camlock, limited metric threading (if any), zamak gears. I don't see a 4-jaw chuck, follower rest, steady rest, faceplate, or tailstock chuck in the picture; if those aren't hiding in the cabinet, you may be able to get them on ebay. A quick change tool post would be in order.
CNC operation will bypass a lot of the Zamak gears. CNC will let you cut metric threads.
Rigidity may be poor for a 12" lathe but how does it compare to a smaller lathe when taking similar cuts on the same size work? The difference will be less. Don't expect to do heavy hogging but if you treat it like a light duty hobby machine instead of a production lathe and work within its limits you should be ok.
Get that can of WD-40 away from the lathe (you can use it to disolve gunk, though) and get some way oil and spindle oil. You can get starter bottles of both as a set on ebay from a couple sellers now for $11 to $16 shipped; seach for "spindle way oil".
Since you may be new to machining, the following 10 videos may be useful:
http://techtv.mit.edu/videos/142-machine-shop-1
Asking prices are often way out of line so look at completed sales where possible and compare condition and accessories.
With the G0602 you would probably get a good set of lathe specific accessories and steel gears instead of zamak but poorer quality castings and you would probably need to do a little work to improve the fit and finish. The G0602 may be a bit more rigid. The G0602 can do metric threading but the quick change gear box is rather limited and you would probably need to swap change gears to go between common thread sizes. And you would give up the longer ability to do longer or wider work, though the G0602 may be a little more rigid. You might get a bad one or have it damaged in shipping and have to wait to send it back and get a replacement and physically hassle with moving the old lathe, the new broken lathe, and the new replacement lathe.
Buy new or buy used, you are rolling the dice, these days. You have that one in hand and can assess its condition. You have it and it is good enough for hobby use. Unless a collector is willing to give you a lot more than it is worth as a functional tool, you may as well keep it. If you buy the accessories you might be missing on ebay before you need them yesterday, you may not spend too much for them.
http://www.lathes.co.uk/craftsman/page3.html
http://www.lathes.co.uk/atlas/page3.html
woodnerd
09-24-2010, 03:51 PM
Thanks for all the replies.
In the pile of stuff from my dad, there is a 4-jaw chuck, a faceplate, three or four additional toolholders, and some other stuff that I have no idea what they are.
The WD40 was for cleaning cosmoline off another machine, just happened to be sitting on the lathe. The pile included some way oil, although for all those years I thought my dad was muttering about "whale oil".
getrdun
09-24-2010, 08:16 PM
i think you'd kick yourself later for unloading it.
Dr Stan
09-24-2010, 08:28 PM
2X on that sentiment and on converting it to CNC. As to selling it and getting a Grizzly that would be a downgrade.
For an entry level CNC take a look at Shoptask. It's Chinese iron and US electronics and software.
whitis
09-24-2010, 08:31 PM
Post pics and someone can probably help you identify the mystery stuff; that happens a lot around here. Maybe a separate pic of the stuff you can identify, too, just to make it a proper tool gloat :).
09-24-2010, 10:16 PM
It's so clean that it just might be worth selling it to get enough for anotehr heavier machine AND tooling..... It's virtually unused-looking and should go at a substantial premium
But, you HAVE IT, and a good machine you HAVE is worth many that you "might buy"......
But it's clean enough that you may be afraid of it....
But it's new enough to do really nice work, no wear, etc..... Getting anotehr machine in that condition is gonna be tough...... It looks nearly showroom new.
I am not a fan of Atlas, but if you have one that nice and un-worn, I see no reason to move it on for mere $$. They can do good work like any other machine can..... I just don't personally like them that much. Many many folks DO.
MarkBall2
09-24-2010, 10:26 PM
Average price's go from $1200-1500. This one is the "underneath drive" lathe, which is one of the most desirable lathes Atlas made for Sears.
That it has sentimental value, is a plus, but difficult to put a price on.
Price it at $3000-$4000 & stay firm. That way if someone wants it worse than you do, you have a bit of change you can apply toward a different one. If nobody want's it, you have a very good lathe. No matter what the naysayers have to say about it.
smiller6912
09-24-2010, 11:09 PM
My vote. Absofreakinlutly keep that thing and use it.
If you part with it you eventually will be sorry, no mater what else you get latter, you will always find a use for this sweetheart.
wooleybooger
09-25-2010, 12:01 AM
thats what i was looking for when i started looking,didnt find it but found a bigger,heavier Rockwell for free. atlas is not heavy,not very stiff and wont take a heavy cut but sometimes a lathe that size is the machine for a 2 minute job. since it was free and was your fathers i would keep it. parts come up on e-bay quite often.. good beginner lathe,moves in all the right places.
