Anyone got any special home methods for lapping inside holes
how to lap inside holes
These are a rather effective, inexpensive option: Expandable Brass Cylinder LapsLast edited by Arthur.Marks; 09-27-2010, 05:51 PM.
The cheap easy way. Get a rod alittle smaller than the hole and cut a slit in it lenghtwise and slide emery cloth in it and put the whole thing in thehole and spin with a drill. Maybe some lub/coolant . I use zippo lighter fluid, useat yourown risk
Originally posted by ahidleyThe cheap easy way. Get a rod alittle smaller than the hole and cut a slit in it lenghtwise and slide emery cloth in it and put the whole thing in thehole and spin with a drill. Maybe some lub/coolant . I use zippo lighter fluid, useat yourown risk
Its a dogs life
Originally posted by pasofinoAnyone got any special home methods for lapping inside holes
Just ask 'em for a demo.
Make an appointment with your Physiotherapist though.
Originally posted by JRoucheWhat?? Ya never seen outside holes? Really got to get out more often, and up earlier, they go quick JR
Donut holes, yes, outside holes.
HEY!
That ain't funny, there is diabetics on here you know.............Geezzz! That looks goooood."Those who hammer their guns into plows will plow for those who do not."~ Thomas Jefferson
You can make a lap out of a piece of alum bar stock.
Turn it just slightly smaller than the hole you want to lap.
Drill and tap the end for a set screw.
Slit it lengthwise past the tapped hole
Charge it with lapping compound and have at it.
As the lap wears and the hole gets bigger adjust the set screw.
You can get lapping compound from an autosupply store or McMaster-Carr
Lapping
I use the "sandpaper on a stick" method a lot to get a better surface finish. If you do that, don't come out of the hole very far - maybe 1/8" - or you'll make the opening of the hole bigger. On a through hole it will be hourglass shaped.Kansas City area
